Old 03-29-2016, 04:30 PM   #1
Camp-N-Nut
camp-n-nut's Avatar
50 to 30 amp plug
My 5th wheel is 50 amp and I want to wire (connect) a 30 amp cord to the 50 amp female plug. It's only a short cord so I can connect my camper at my house without having to drag out the long heavy 50 amp cord. I will not be using any large electrical devices while using this cord. Mainly just to charge the batteries and run the refrigerator. Looking how to wire this as a 50 amp has 2 "hot" wires and a 30 amp don't.
2015 Cedar Creek 34 RLSA
2006 Dodge Laramie Dually Cummins
No Harley Davidson
No John Deere
No CAT
NO OBX
camp-n-nut is offline   Reply With Quote
Old 03-29-2016, 04:40 PM   #2
Mr. Dan's Avatar
Don't wire it. Buy an adapter similar to this (or did I misunderstand something?):
https://www.etrailer.com/search/50a+To+30a+Adapter
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 03-29-2016, 05:26 PM   #3
Camp-N-Nut
camp-n-nut's Avatar
Adapter is too short. Wire needs to be 4 feet long so I can plug it in. I already have the wire and plug ends. Just need to know how to wire the 30 amp cord to the 50 amp female plug. Thanks.
No Harley Davidson
No John Deere
No CAT
NO OBX
Old 03-29-2016, 05:49 PM   #4
Head Rambler
There are no 240 volt loads in the RV so you can make up a cord that connects both hots on the 50 amp receptacle to the one hot on the 30 amp plug and then neutral to neutral and ground to ground. That's what the proper adapter does.
If you don't understand the above, you should get an electrician familiar with RV electrical systems to build it for you.
Be aware that with this setup you CAN run both A/C's, BUT you will more than likely overload the 30 amp circuit and trip the 30 amp breaker feeding the cord.
Gotta go campin!
Old 03-29-2016, 05:55 PM   #5
Mr. Dan's Avatar
To second Bama Rambler's post, I invite you to see the diagram in post #35 of this thread:
Hw50 wired to 30 amp trailer
Old 03-30-2016, 07:57 AM   #6
Camp-N-Nut
camp-n-nut's Avatar
Just want to wire a 30 amp wire to a 50 amp female plug.
No Harley Davidson
No John Deere
No CAT
NO OBX
Old 03-30-2016, 08:25 AM   #7
chrisbailey13's Avatar
It sounds like you want end up with a 4 foot cord that looks similar to this
In order to do that you have to pic up a female adaptor end
and start with a 4 conductor cord. (critical).
the other end of the cord you would attach an adaptor like this
As others have mentioned, you will need to wire the black and red hot wires from the 50amp side to the single hot on the 30amp side... Neutral to Neutral, Ground to Ground.
Am I understanding your situation correctly?
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 03-30-2016, 08:27 AM   #8
Dazed & Confused
M&K Hoffman's Avatar
Looks like you will need to make one to get the length you want. I found 25 foot 30 amp RV cords ( with and w/o female ends) for as low as $35 on E Bay and a 50 amp female RV connector for $15 dollars on the WalMart site. Cut the cord to the length you want than attach the 50 amp female as shown below.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 03-30-2016, 08:34 AM   #9
Camp-N-Nut
camp-n-nut's Avatar
Thanks for everyone's help. Got it all wired up and it works great!
No Harley Davidson
No John Deere
No CAT
NO OBX
Old 03-30-2016, 08:46 AM   #10
Youroo!!
