I think the problem with this is that it assumes that the RV pedastal is wired with the 20amp and 30amp breakers separately. If I recall from prior discussions about these "cheater boxes" that this isn't always the case and you're still limited in what you can pull/use.
And, ironically- I just read a campground rule that basically talked about now allowing this. Something to the effect of "you can't pull more amps than the hookup provides" or something weird. It was vague but made me think of these "cheater cords" and/or the autoformers.
BUT- I really don't know enough about this stuff to speak intelligently about it. Just the tiny bit that I think I've gleaned from the forums.
