Old 05-11-2016, 11:04 AM   #11
leefl's Avatar
Originally Posted by NavigatorC130A View Post
First off - I love the mod. We are new owners of a 2013 unit identical to yours. I have a hard time understanding why FR didn't do this in the first place.
Anyways - what an I missing? What is the reason for having 2 valves in the line from the kitchen gray water tank?? cable valve and reused valve?? Why not just have the cable valve?
Originally I was just going to reuse the existing valve where I now have it, near the tee, but I was concerned about having the weight/pressure of water in the new pipe while traveling.
I then considered just adding the new cable release valve to avoid that weight, but was concerned that if there wasn't a valve near the tee that the black tank water might backwash into the new pipe and sit there (if not ready to flush the kitchen tank immediately after the black tank).
Since I had the old valve ready to use, and only needed to add a couple of flange connectors, I decided to do both and prevent both the weight of water in the pipe while traveling, and prevent any backwash.
Pulling two handles to dump really isn't any inconvenience.
You could certainly do without the reused valve, but having two sets of flange fittings made it easier to do final assembly too.
leefl is offline   Reply With Quote
Old 05-16-2016, 10:03 AM   #12
Iwannacamp's Avatar
I think the instructions are a little "weak".
Hello. Just kidding. Did you write instruction manuals for NASA or something?
Great job!
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 05-17-2016, 12:56 PM   #13
leefl's Avatar
Great job!
Haha, not exactly, but I did work for Rockwell many many years ago, including some govt work, with very strict process documentation requirements
(creating prototypes of new equipment and then having to write-up documentation on how to make a production ready version)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
Old 05-23-2016, 11:09 PM   #14
mstell2's Avatar
I did similar thing to mine, makes it a whole lot better to dump. Click image for larger version
Name:	ImageUploadedByForest River Forums1464062943.682923.jpg
ID:	108803Click image for larger version
Name:	ImageUploadedByForest River Forums1464062957.615825.jpg
mstell2 is offline   Reply With Quote
Old 05-24-2016, 06:35 AM   #15
leefl's Avatar
Excellent! Nice work
5er, 8281ws, black, drain, dump, fifth wheel, rockwood, sewer, grey water, modifications
