Old 01-30-2013, 09:51 AM   #1
Firefighter938's Avatar
921 LED replacement bulbs!
Here is a link below for the bulbs shown in my pictures. They are very nice and very cheap! One note when installing they are directional so they have to be into the socket a certain way. If the panel is facing the fixture you just have to bed it down a little. The yellow/white light picture is a picture of the old (yellow) and new (white) bulb in same fixture. The white/white picture is with one panel facing and the other panel directed down (NOT A BIG DIFFERENCE). The camper picture is with all bulbs changed out. They are .9watts each, compared to 4/6/8/10 or 12watts for the common bulb. I have 16 bulbs in my camper and I am only pulling 14.4watts compared to 64-192watts with old light bulbs.
20pcs T10 194 921 W5W 24 1210 SMD LED White RV Landscaping Light Lamp Bulb | eBay
Name:	LED BULBS.jpg
ID:	23660   Click image for larger version
ID:	23661   Click image for larger version
ID:	23662   Click image for larger version
Keith & Casie
2013 Dodge Ram 1500 Quad Cab Hemi
2013 Avenger 261LT Bunkhouse
Firefighter938 is offline   Reply With Quote
Old 01-30-2013, 10:03 AM   #2
Graduate Member
RoadTrip's Avatar
Thanks! Looks good
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 01-30-2013, 10:11 AM   #3
I also installed these last fall. I don't have a picture yet. They worked GREAT self stick to awning and they roll right up! I am going to order another set to go under the camper. They will light up the ground on the entry side of the camper. Shipping on these took about 2weeks.
http://www.ebay.com/itm/120827434629...84.m1438.l2649
Keith & Casie
Old 01-30-2013, 10:40 AM   #4
Graduate Member
RoadTrip's Avatar
I think herk and someone else did those awning lights also. They were just talking about that controller in the last couple days.
Looks cool - i added it to my wish list.
2013 - 53 days
2012 - 26 days
Old 01-30-2013, 11:37 AM   #5
SYE
SYE's Avatar
I think that these would be nice, but you said that the bulbs were directional so I dont believe that they would work good for my over the table and counter lights behause they hang down.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-30-2013, 11:39 AM   #6
SYE
SYE's Avatar
The 921 bulbs are the only ones that are not LED, the rest of the camper came with LED.
Scott & Vicki
Old 01-30-2013, 01:37 PM   #7
Yea, I'm not sure this style bulb would work in that type of fixture. Your probably better off looking for a round barrel shape bulb instead of the flat type.
Keith & Casie
Old 01-30-2013, 03:15 PM   #8
Phat Phrog Stunt Crew
awwall's Avatar
I replaced my 921 bulbs with this one. I preferred the warm white vs the bright white. Also, extremely quick delivery from this seller.
1pcs T10 921 194 SMD Bulb 25 1210 LED Bulbs Lights Warm White | eBay
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 01-30-2013, 05:17 PM   #9
10x
Do they get hot? Does the fixture need modifying for heat?
10x is offline   Reply With Quote
Old 01-30-2013, 06:30 PM   #10
They do not get hot, and no modifications were needed. One of the biggest benefits of LED are they do not produce heat.
Keith & Casie
