Old 01-30-2013, 10:51 AM   #1
Firefighter938's Avatar
921 LED replacement bulbs!
Here is a link below for the bulbs shown in my pictures. They are very nice and very cheap! One note when installing they are directional so they have to be into the socket a certain way. If the panel is facing the fixture you just have to bed it down a little. The yellow/white light picture is a picture of the old (yellow) and new (white) bulb in same fixture. The white/white picture is with one panel facing and the other panel directed down (NOT A BIG DIFFERENCE). The camper picture is with all bulbs changed out. They are .9watts each, compared to 4/6/8/10 or 12watts for the common bulb. I have 16 bulbs in my camper and I am only pulling 14.4watts compared to 64-192watts with old light bulbs.
20pcs T10 194 921 W5W 24 1210 SMD LED White RV Landscaping Light Lamp Bulb | eBay
Name:	LED BULBS.jpg
ID:	23660   Click image for larger version
ID:	23661   Click image for larger version
ID:	23662   Click image for larger version
Keith & Casie
2013 Dodge Ram 1500 Quad Cab Hemi
2013 Avenger 261LT Bunkhouse
Firefighter938 is offline   Reply With Quote
Old 01-30-2013, 11:03 AM   #2
Graduate Member
RoadTrip's Avatar
Thanks! Looks good
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 01-30-2013, 11:11 AM   #3
I also installed these last fall. I don't have a picture yet. They worked GREAT self stick to awning and they roll right up! I am going to order another set to go under the camper. They will light up the ground on the entry side of the camper. Shipping on these took about 2weeks.
http://www.ebay.com/itm/120827434629...84.m1438.l2649
Keith & Casie
Old 01-30-2013, 11:40 AM   #4
Graduate Member
RoadTrip's Avatar
I think herk and someone else did those awning lights also. They were just talking about that controller in the last couple days.
Looks cool - i added it to my wish list.
2013 - 53 days
2012 - 26 days
Old 01-30-2013, 12:37 PM   #5
SYE
SYE's Avatar
I think that these would be nice, but you said that the bulbs were directional so I dont believe that they would work good for my over the table and counter lights behause they hang down.
Scott & Vicki
2021 4 reserved
SYE is offline   Reply With Quote
Old 01-30-2013, 12:39 PM   #6
SYE
SYE's Avatar
The 921 bulbs are the only ones that are not LED, the rest of the camper came with LED.
Scott & Vicki
2021 4 reserved
Old 01-30-2013, 02:37 PM   #7
Yea, I'm not sure this style bulb would work in that type of fixture. Your probably better off looking for a round barrel shape bulb instead of the flat type.
Keith & Casie
Old 01-30-2013, 04:15 PM   #8
Phat Phrog Stunt Crew
awwall's Avatar
I replaced my 921 bulbs with this one. I preferred the warm white vs the bright white. Also, extremely quick delivery from this seller.
1pcs T10 921 194 SMD Bulb 25 1210 LED Bulbs Lights Warm White | eBay
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 01-30-2013, 06:17 PM   #9
10x
Do they get hot? Does the fixture need modifying for heat?
10x is offline   Reply With Quote
Old 01-30-2013, 07:30 PM   #10
They do not get hot, and no modifications were needed. One of the biggest benefits of LED are they do not produce heat.
Keith & Casie
Old 01-30-2013, 07:58 PM   #11
awwall's Avatar
And use about 1/10 the power. Great for those that boondock!!
FROG Member
Old 07-25-2014, 05:41 PM   #12
LED Bulbs
I am very much interested in changing to the 921 LED bulb. Where exactly did you obtain yours? I have about 12 I want to replace. Thanks
jimbeki is offline   Reply With Quote
Old 07-25-2014, 05:44 PM   #13
I am very much interested in changing our my 921 bulbs to the 921. Where did you obtain yours?
Old 07-25-2014, 05:52 PM   #14
Is this what your looking for?
Search Results For "921-cw12" | LED Products | Super Bright LEDs | Super Bright LEDs
I have swapped mine to LED's as well, it has made a solid difference in battery power consumption. Easy to change as well,
Rockwood Roo is working out better than I ever expected.
2012 Rockwood Roo 21ss
TV- 2015 Dodge Ram 1500 w/tow package
Camping fan is offline   Reply With Quote
Old 07-26-2014, 09:12 PM   #15
M4.com
10Boomer is offline   Reply With Quote
Old 07-27-2014, 01:02 PM   #16
f5moab's Avatar
I agree they do not get hot; however, they do produce heat. In fact, those LEDs shown are mounted to a heat sink and some of the LEDs used as headlamps in newer vehicles have cooling fans to keep them from burning out.
f5moab is offline   Reply With Quote
Old 07-27-2014, 01:45 PM   #17
BooBoo23's Avatar
Take a look at item # 261298784876 on Ebay right now. 20 of them for $9.99.
Let's face it, all the LED's are made in China. Just remember most LEDs have polarity and if they don't work just turn them 180 degrees and put them back in.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 07-27-2014, 09:25 PM   #18
camaraderie's Avatar
Good tips! Getting some!! Thanks.
