Old 08-13-2015, 08:16 PM   #1
A couple small mods I've done
My wife and I picked up our camper less than two weeks ago, so I haven't had much chance to do a lot yet. Here's a few small things I've done:
Added paper towel holder
Added a key rack
Added a 12v fan in the bottom bunk
Added dedicated 30 Amp service to plug it in at home!
ID:	85573   Click image for larger version
ID:	85574   Click image for larger version
ID:	85575   Click image for larger version
ID:	85576   Click image for larger version
Craig
2016 Wildwood 30QBSS
2012 Ram 3500 Longhorn 6.7 CTD 4x4
giarc25 is offline   Reply With Quote
Old 08-13-2015, 09:09 PM   #2
I picked up the 12v fan from the automotive section at Wal-Mart for about $12. It came with an on/off switch located about 6" from the fan on the cord. I took the switch out of the switch box and relocated the switch into the fan housing, on the back, and then fished the power wire to the nearby light to pick up power. Finished product is very clean looking, and worked out great!
ID:	85604   Click image for larger version
ID:	85605   Click image for larger version
Craig
Old 08-13-2015, 09:22 PM   #3
mud yapster's Avatar
Looks good. Yep you have to have power hook up at home and water hook up. It can be used to get away when you want. Or camp in the yard. LOL I do. You have 2 homes on the same lot. Nothing like away from home at home. LOL
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-14-2015, 05:27 PM   #4
riznfall's Avatar
Looking good. Only get worse from here on out. That's half the fun. It's all apart of making it your own.
Tim
2015 Ram 3500 CCLB dually
2015 39R12 Vengeance touring edition.
Tim
Vengeance touring edition 39R12
2012 Dodge Ram 3500 DRW
riznfall is offline   Reply With Quote
Old 08-15-2015, 12:21 PM   #5
Man that's one nice electrical hookup. good luck with your rig.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
SULTINI is offline   Reply With Quote
Old 08-15-2015, 04:06 PM   #6
I go RV'ing not Camping
jgourlie's Avatar
I am really jealous of your electrical hookup at home....Really nice work on that!
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 08-15-2015, 04:18 PM   #7
Just a member
kandl's Avatar
X2 - DW was cleaning up the other day after our latest excursion and had the AC going and lights on via the 110 adapter. And that's about all the 15 amp beaker will handle. Fired up the vacuum and... poof!
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-15-2015, 06:38 PM   #8
alsimmon11's Avatar
Mods
Mods look good. Has anyone redone the floor on a Georgetown with tile. Thinking about removing the carpet and putting tile up front from the bathroom forward.
alsimmon11 is offline   Reply With Quote
Old 08-16-2015, 01:03 AM   #9
Tom48's Avatar
Watch out for voltage drop when you do that. Maybe a $15 volt meter plugged in to an easily visible plug.. If voltage drops below about 106 -108 v I would not recommend running my ac
Tom48 is offline   Reply With Quote
Old 08-20-2015, 11:44 PM   #10
Thanks y'all! In my previous life I was a commercial electrician for 10 years, so this was easy for me to do myself. Nearly $300 in material and a few hours of time I was up and running!
The story:
I had to run a dedicated 30 amp service for the TT because I used my adapter and plugged it into the garage. After running the A/C for about an hour the breaker tripped. I reset the breaker, after reducing the load (moved garage fridge to another circuit and unplugged the unused chest freezer). After resetting the breaker, the A/C on the TT ran for about 4 hours and we ran an errand to the grocery store. Upon coming home the A/C wasn't running. I went and checked the breaker and it was still on. I checked breakers in the TT and they were on. I pulled the plug out of the receptacle and my extension cord had burned up on the end. I am lucky the house didn't burn down! Federal Pacific electrical panels were banned in 1974, or somewhere thereabouts, for that exact reason...breakers don't properly trip.
Needless to say, there are no worries now
Craig
modifications
