Old 04-20-2014, 05:04 PM   #1
dsrace's Avatar
a few additions
I have two friends with ceiling fans in there fifth wheels and I really liked them because they move more air than a fan on the counter. I should say they move air over a larger area. also on our last trip my wife fell off the step ladder so I decided since our toy hauler didn't come with a vent hood over the range since it has no oven but rather a microwave/convection over ( I don't like the convection oven it doesn't cook pizza as well) but they put a manual roof vent over it instead. so I decided we needed a power vent with power lid as well. so I pulled the inverter/breaker box out since there were two available 12 v slots left and routed all wired back to it. I bought everthing with wall switch's rather than remotes cause batt's go dead and remotes disappear!! lol
ID:	50444   Click image for larger version
ID:	50445   Click image for larger version
ID:	50446   Click image for larger version
ID:	50447   Click image for larger version
ID:	50449   Click image for larger version
ID:	50450   Click image for larger version
ID:	50451   Click image for larger version
ID:	50452   Click image for larger version
'99 f350, quad cab long box, dually, 6 speed manual, gently mod'd.
2011 wolf pack 295 with full susp now!
dsrace is offline   Reply With Quote
Old 04-20-2014, 05:08 PM   #2
dsrace's Avatar
more pics
ID:	50454   Click image for larger version
ID:	50455   Click image for larger version
ID:	50456   Click image for larger version
ID:	50457   Click image for larger version
ID:	50459   Click image for larger version
ID:	50460   Click image for larger version
ID:	50461   Click image for larger version
ID:	50462   Click image for larger version
Old 04-21-2014, 07:59 PM   #3
dsrace's Avatar
i'm going to add a fan to the fridge vent next and then I will flip the axles so I want to go to 235 80 16 tires from 225 15's cause I need atleast 2" more ground clearance which will also require a new set of steps.
Old 06-07-2014, 06:43 PM   #4
dsrace's Avatar
well i used the toyhauler for a week and that ceiling fan was worth every penny! the power vent was a great addition too. the ceiling fan works better than an oscillating fan!
Old 06-15-2014, 08:29 PM   #5
Is the ceiling fan 12 volts dc or 110 volts ac?
clutchd is online now   Reply With Quote
Old 06-15-2014, 09:05 PM   #6
dsrace's Avatar
12 v dc and a 110 would've moved more air but i wanted to be able to run it while i wasn't plugged in or if i had to pull over for the night. pulls 2.6 amps on high and was well worth it even while plugged in on a 95* day. we went down to oklahoma and the last 3 days of the week were 95* so i ran it non stop for 1 week with no problems.
Old 06-16-2014, 07:18 AM   #7
cpaulsen's Avatar
The ceiling fans work great.Have one in the LV of the 5ver and I added one to the bedroom.
cpaulsen is offline   Reply With Quote
Old 07-13-2014, 03:01 PM   #8
dsrace's Avatar
our ceiling in the bedroom of our th'er isn't high enough to add one or i would've at the same time. it would be very nice to have on in there and the roof isn't thick enough to recess a spot for one, i checked that too.
Old 07-14-2014, 07:46 PM   #9
2014 XLR 27HFS
I want the 12v ceiling fan. Where can I buy it? Did the wall switch come with it, or did you buy separately? If separate, do you have a link for that as well?
Thanks in advance,
- Dave.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 07-15-2014, 09:02 AM   #10
dsrace's Avatar
just type in 12 volt ceiling fan on ebay or camper or rv ceiling fan and there are several to choose from
