Old 08-07-2010, 03:05 PM   #1
A few more mods
Just a couple more mods since 06
1, shower skylight cover useing snaps and original holes (stopping the heat)
2, carring firewood so it does'nt interfer with the slider
Mark & Connie
2006 28RK Wildcat / 2006 Chevy CC 4x4 Diesel / 6 SPD Allison / RBW Slider
Pioneer in-dash navigation / Firestone airbags with in-cab controls /Prodigy Brake Controler / Honda EU3000 with wireless remote starter
rdsknfn_57 is offline   Reply With Quote
Old 08-08-2010, 09:29 AM   #2
where did you get the shower cover?
bwssr is offline   Reply With Quote
Old 08-08-2010, 01:23 PM   #3
bwssr, it's from a local rv dealer . I'ts acually called SOLAR ENTRY DOOR WINDOW COVER, campingworld sells them for around $12. if you go online to campingworld type in the name and comes up .
Mark & Connie
Old 08-08-2010, 02:02 PM   #4
2Susan's Avatar
Interesting! Does the shower cover really make a difference?
Covering the shower skylight is an interesting idea. Does it really make that much of a difference?
I can't exactly see from the photo - but it looks like you used a screw in snap to hold it in place?
I'm thinking this could be an easy DIY project - snaps on fabric tabs on the corners of a fabric bag with the bottom layer a piece of foam core - on top thick batting. Just a little bit of sewing and only the bottom has to look pretty.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 08-08-2010, 03:58 PM   #5
cool! Thanks!
Old 08-08-2010, 10:48 PM   #6
2Susan, it makes a world of difference, when it's hot outside that is where the majority of the heat comes in from, the shade works great to stop it. You are right i used a screw in snap in the original holes that hold the frame work up so i didnt have to drill any new holes at all. Here is a picture taken looking straight up, it does'nt block all the light but the light was never the issue it was the heat.
Mark & Connie
Old 08-09-2010, 11:13 AM   #7
I take it you had to add the snaps to the cover? The description on the CW site says velcro is used to attach the cover.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-09-2010, 10:22 PM   #8
revrnd, you are right , the cover came with velcro and lasted about 2 hrs The glue let go from the heat and it was on the shower floor. I stared at it for awhile and decided on snaps. Snap on Snap off , been on for a month now, on days that it's really hot, i unsnap 1 corner to let some heat out. On another site some one posted that after covering there skylight completly, the heat cracked his skylight. so hopefully unsnapping 1 corner will let enough heat out.
Mark & Connie
Old 08-09-2010, 10:31 PM   #9
Did you use snaps that were attached to screws, or just used plain snaps w/ the original screws? I have some domes (snaps) somewhere around the house. I should've lightened the inventory @ work when I left (plant was closing in 5 months). I imagine most of our shop supplies were scrapped.
I checked @ Lowe's & Canadian Tire here in Ontario & nothing. I'll check w/ my supplier from my working days if they have stock to sell over the counter or do I have to buy a hundred.
I'll remove 1 of the screws to check the threaded length.
Just an idea. I wonder if you had access to your roof, if you could just put the solar blanket on the top of the skylight? Take the reflective mat'l & make it larger than the skylight & add some weight to the outer edge.
Old 08-10-2010, 07:29 AM   #10
Fabric stores carry the snaps, and most boat supply places as well. Look for the stainless steel ones.
