Old 09-12-2015, 03:41 PM   #1
AC Return Vents - Fixed and Modified
Well we have a Cedar Creek 38FL and the air return vents are located over our bed. They are installed with 2 wood screws - one of which appeared to be not holding on to anything. Well it was finally time to clean the filters. I knew this was going to lead to some additional work....
1. Removed the screws - one screw was not even into the wood. Just kinda hanging on to the cardboard for the filter.
2. Cleaned filters and vents
3. Drilled new holes for 8/32 screws
4. Mounted the screws sticking down and put fender washer on each side of the wood panel. Added a nut and tightened down.
5. Put the vents and filters back up and then used cap nuts over the screws to keep everything together and easy to remove next time for cleaning.
Total cost about $3.00
These were attached to the ceiling with wood screws originally.
Name:	2015-09-12 13.26.31.jpg
Name:	2015-09-12 13.29.02.jpg
Name:	2015-09-12 13.30.16.jpg
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 09-12-2015, 03:55 PM   #2
Mr. Dan's Avatar
Looks good.
Are 8/32" screws roughly the same as 1/4"?
Old 09-12-2015, 03:58 PM   #3
Bama PrimeTime's Avatar
Very good job. It looks like it should have came that way.
John
Ted
Bama PrimeTime is offline   Reply With Quote
Old 09-12-2015, 04:07 PM   #4
gashog's Avatar
Believe 38FLCamper meant 8-32 (no.8 with 32 threads per inch). Looks nice and great permanent fix to sloppy manufacturing..
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 09-12-2015, 04:56 PM   #5
Yes I did mean #8-32 screws - 3/4" long
Walter & Donna
Old 09-12-2015, 04:59 PM   #6
Mr. Dan's Avatar
Thanks, I need to do this to my Wildcat which has a "rounded" ceiling.
Sent (I think)
Old 09-12-2015, 05:50 PM   #7
Yes our ceilings are rounded around both vents so they don't sit completely flush but they are tight and will not drop now.
Walter & Donna
Old 09-13-2015, 12:24 PM   #8
nice job I have the same model 38FL have you found new filters to install ?or did you make your own?
wire1946 is offline   Reply With Quote
Old 09-13-2015, 01:56 PM   #9
I just vacuumed (carefully) the existing ones. I have seen this filter material in many different stores but would have to make our own. I do plan on building a frame out of some material other than the crap paper they have so that it works better. Still working on that one though.
Walter & Donna
Old 09-13-2015, 02:03 PM   #10
Originally Posted by Mr. Dan View Post
Looks good.
No, about 2/3 the size. #14 screws are about 1/4"
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 09-13-2015, 06:38 PM   #11
Air filters for 39FL cedar Creek
Thanks for the post. I have been thinking about these filters sine I bought unit.
You also have 2 returns in living room. I went and bought the filter media in many different stores. I buy a large cardboard filter and just cut out filter sizes and replace. I get about 4 (just right for one filter). I try to get the thinnest size and I take off dirty filter and staple it on. Takes about 30 min. or less. I have been looking for a while for a roll with the thin material.
Thanks again..........
Forever young.......Craigi 👍🏻😎
craigi is offline   Reply With Quote
Old 09-14-2015, 07:45 AM   #12
Mr. Dan's Avatar
Jim
Yes, thank you. We got that covered in a couple of entries posted before yours. Notice that I added the " (inch indicator mark) to the OP's 8/32 notation. Just joking there... but thanks for taking it seriously and helping me in overtime.
vent, modifications
