Old 03-26-2016, 09:44 PM   #1
Added a Fireplace to our Rockwood 2604WS
Just finished adding a fireplace to our Rockwood 2604WS
Name:	FIRE PLACE.JPG
thunderstruck is offline   Reply With Quote
Old 03-26-2016, 09:57 PM   #2
Nice! I have been thinking of adding one to ours. What brand/model of electric fireplace did you use?
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is online now   Reply With Quote
Old 03-26-2016, 10:29 PM   #3
28.5" Embedded Fireplace Electric Insert Heater Glass View Log
Got it online from Walmart (Almost made to fit)
Old 03-30-2016, 07:16 PM   #4
I did something similar on my 2604, but the water hoses on left side of cabinet only allowed a 23" fireplace.
I see you relocated the subwoofer speaker above.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 03-30-2016, 07:32 PM   #5
m2kamp's Avatar
Attachment 102983
Absolutely Awesome!! Looks great!
I would love to do this as we don't even use the cabinet under our TV.
Is the 28.5" the total width? Could you provide the dimensions?
I just measured my opening and depth, its 27" high, x 32" wide x 8.5" deep.
Thanks!
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 03-30-2016, 07:53 PM   #6
CaptnJohn's Avatar
Factory installed on my 5er and works great! You will really enjoy it!
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 03-30-2016, 08:08 PM   #7
Georgia Rally Coordinator
aceinspp's Avatar
Same here factory install and they are really nice. You will surly enjoy. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 03-30-2016, 08:37 PM   #8
m2kamp's Avatar
At $120 shipped can't really go wrong.
Plus according to the reviews, it puts out really good heat. I rather run this fireplace than the gas furnace, though I would lose the ducted heat.
Old 03-30-2016, 08:51 PM   #9
Thanks!
Trailer back in Side yard were slide can only go out half way so tough to measure. But front dimensions are 28 1/2 x 21 x 3/4. I think box on back of unit was about 5 inches deep. I had to clean up some wiring and plumbing and relocate sub woofer. I also move 12 volt power center and made it so Dish box goes behind TV so lower cabinet can be closed when Fireplace is putting out heat.
Old 03-30-2016, 08:53 PM   #10
Good heat no thermostat but High and low or no heat and dimmer on Flames
2604, rockwood
