Old 02-26-2012, 08:14 PM   #1
jtad's Avatar
Added a step light
I added a step light today to my Crusader. I had a 12 volt light in the basement cargo compartment. Opened the wall up and got behind that light and tapped into the power supply. Cut a small hole in the wall material for a switch. There was already a tiny gap in the floor to pass a wire thru. Drilled a small hole to mount a clearance light inside the step area. Hooked the hot wire to the light.. And there you have it one step light. Cost about $10.00Click image for larger version
2011 Cursader 298 BHD
2012 F-250 FX4 6.7 Power Stroke
B&W Companion Hitch
Days Reserved for 2012: 39
jtad is offline   Reply With Quote
Old 03-01-2012, 11:37 AM   #2
LKicklight's Avatar
Step Lights
Did mine kind of similar on the Crusader 270 RET..I now have an interior step light and one on the exterior. Basically attacked it the same way you did, but cut a larger hole in the plywood behind the thin bulkhead on the right side of the cargo compartment..Both operate off one switch mounted on the step riser inside the coach: The Exterior Lite is a Three Bulb LED..Have also planned on putting some LED Amber lights above the Kitchen Wall Cabinets in our coach..just purchased a 300 Bulb LED Lite Strip this morning off EBAY..
LKicklight is offline   Reply With Quote
Old 03-04-2012, 08:21 PM   #3
Gotago2's Avatar
Nice job.
Norm & Paulette
Neverland where growing-up is optional.
2011 Coachmen Mirada 35DS(36") pulling 03 Nissan Frontier
Gotago2 is offline   Reply With Quote
