Old 03-07-2015, 03:43 PM   #1
ETCTA's Avatar
Adding 12 volt Outlets
I have a 2014 Georgetown 351 and I am considering adding a 2 12-volt outlets in the dash. Does anyone have any experience or advice?
ETCTA is offline   Reply With Quote
Old 03-07-2015, 04:03 PM   #2
It largely depends on what you plan to use them for. My only advice would be to plug, wire, and fuse appropriately for the maximum intended use. You will also want to decide if you want them both on a single circuit, or on separate dedicated circuits.
If you are just trying to charge your phone or the like, you can probably get away with just tapping into an existing 12v accessory line. If you are looking to run an inverter, fan, or aux heater, then you might be better served to run a new line.
rana is offline   Reply With Quote
12 volt, electrical
