Old 07-24-2013, 10:35 PM   #1
jtstromsburg's Avatar
adding 2nd AC to tbok
I finally bought a 2nd AC to add to our Sabre. I'm very handy, and in 2 minutes took out the lower ceiling vent cover, found the power wire and the control wires. As far as I know,no just need to pull the vent from above, remove caulking, and get the top AC unit in place...
Any tips or advice before I start? Going to do it tomorrow unless it is raining.
Thanks!
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-24-2013, 10:37 PM   #2
Denver, CO
garbonz's Avatar
Just seal er up good. I assume it is non ducted and control is on the inside ceiling module itself?
2017 Fuse 23T
Old 07-24-2013, 10:41 PM   #3
It's ducted and wall stat controlled. Factory prepped (not sure why I didn't pay the extra $800 to just have it done....)
as far as sealing, I think it's just the foam and clamped with the four mounting bolts, correct?
Joel and Teresa
2016 Sabre 34TBOK
Old 07-25-2013, 10:52 AM   #4
Denver, CO
garbonz's Avatar
Yep that's it.
2017 Fuse 23T
Old 07-26-2013, 08:35 PM   #5
Well, got it installed and running! Took over an hour, but most of the time was searching the attic cavity for wires, figuring out what goes where with the wiring, and getting the top unit centered. Ran it in the driveway and although it is only 72 f out, I was still impressed with a 40 f discharge temp.
Even ran both 15k AC's st the same time on 30a service. Each unit pulled 12-13 amps while cooling. Pretty happy and appreciate the feedback on here.
Joel and Teresa
2016 Sabre 34TBOK
Old 07-26-2013, 11:14 PM   #6
station10fd's Avatar
I'm doing the same thing next weekend, how hard was it to connect the ducting? Did you have to cut the foamboard to go around the existing ducts? I ordered a penuin II with heat strip. They said I had to have a different thermostat than what was supplied with my sabre, so one of those is coming also. Thanks!
__________________________
Mike T.
2013 Chevy Duramax 3500 SRW
2013 Sabre31RKOK
station10fd is offline   Reply With Quote
Old 07-27-2013, 08:20 AM   #7
The ductwork was right there, just cut the silver taped ends, and install. I spent some time sealing up any other openings, to keep air in the ducts. Wasn't too bad. Feel free to pm me if you have questions once you get started. For me, figuring out which wires go where took some time.
Good luck
Joel and Teresa
2016 Sabre 34TBOK
