Old 05-22-2014, 06:31 PM   #11
Lynkage's Avatar
Originally Posted by gljurczyk View Post
add a time delay to one so you do not pull so many amps at start-up. You can get a delay from a A/C dealer. Get a delay that will off set them like for 2 or 3 mins. Your start up is causing to many amps to get out of the start winds. make sure it breaks at shut off, and the energizes at startup that will offset your genny voltage.
^ This!!+1
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 05-22-2014, 08:42 PM   #12
TURBS's Avatar
I have a thread on this very issue as well as a fix.
Originally Posted by Lynkage View Post
^ This!!+1
TURBS
"Sabre owners united"
Old 05-22-2014, 08:44 PM   #13
TURBS's Avatar
Here.
air conditioner for generator mod
TURBS
Old 05-22-2014, 09:19 PM   #14
Dijoeboss's Avatar
What really irks me is this should not even be an issue!! If the Rv was built right, or a bigger generator, this wouldn't even be a concern, but like every other mfg. they go cheap! Onto graingers it is!! Thanks for the help and info!! I will keep ya posted!
Dijoeboss is offline   Reply With Quote
