Old 05-18-2014, 04:34 PM   #1
Dijoeboss's Avatar
Adding a hard start capacitor/ can I ?
I have a 2012 Georgetown XL, can I add a SPP6 hard start capacitor to this?Click image for larger version
Name:	ImageUploadedByForest River Forums1400448773.447755.jpg
Dijoeboss is offline   Reply With Quote
Old 05-18-2014, 05:04 PM   #2
Todouble's Avatar
Yes. That's a run capacitor. Put the hard start across the two terminals. Common and hermetic.
Todouble is offline   Reply With Quote
Old 05-18-2014, 06:11 PM   #3
Dijoeboss's Avatar
Cool, that's what I thought and that's how I had it wired, was just needin the reassurance before I powered up the generator and a/c units!
Seems to be working ok! Will know for sure this summer in the heat if it helps!
Old 05-20-2014, 09:07 AM   #4
afg83133's Avatar
What is that for? And what is the purpose??looks interesting.
Thanks in advance
afg83133 is offline   Reply With Quote
Old 05-20-2014, 09:14 AM   #5
Where can i get one? Can this be used with a portable generator?
Kuba is offline   Reply With Quote
Old 05-20-2014, 09:21 AM   #6
Todouble's Avatar
There used to help start the compressor faster. Helps with the voltage sag during startup which helps the generator a lot. I get mine at an a/c supply house. Google supco spp6 I think is the number
Old 05-20-2014, 10:10 AM   #7
TURBS's Avatar
Originally Posted by Dijoeboss View Post
I have a 2012 Georgetown XL, can I add a SPP6 hard start capacitor to this?Attachment 52699
And actually it'll fit right beside to!
TURBS
"Sabre owners united"
Old 05-20-2014, 10:13 AM   #8
TURBS's Avatar
OK lets stand it up.
:beer:
TURBS
Old 05-22-2014, 05:50 PM   #9
Dijoeboss's Avatar
Well that STILL didn't fix my generator a/c issues!!!!!
With generator running, running both a/c units, in the heat of the day, the transfer switch will dis engage and buzz rapidly when the a/c tries to cycle, have to shut off one of the a/c units and let generator- transfer switch pull back in....
Had this all checked out at an Rv dealer, , couldn't find anything wrong!
Even replaced transfer switch.... No fix yet..... Added 2 new hard start capacitors thinkin this might help... Nope!
Any other ideas?
Old 05-22-2014, 06:17 PM   #10
Witch Doctor's Avatar
Any other ideas?
add a time delay to one so you do not pull so many amps at start-up. You can get a delay from a A/C dealer. Get a delay that will off set them like for 2 or 3 mins. Your start up is causing to many amps to get out of the start winds. make sure it breaks at shut off, and the energizes at startup that will offset your genny voltage.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
