Old 08-05-2016, 03:36 PM   #11
Originally Posted by Bama Rambler View Post
If your unit is prewired for the second A/C then the power wiring is already in the ceiling at the vent opening. Also, the bracing is already in place for it as well.
This is true for his and my unit for the bunk rooms however I dont think it is for the master bedrooms. I know there is a sticker at the vent in the bunk room that says it is prewired but I dont see one in the master bedroom.
Kris & Alicia
2001 Ford F250 CC LWB 4X4 PSD
B&W Companion Hitch
2012 Sierra 32QBBS
noslofivoh is offline   Reply With Quote
Old 08-06-2016, 06:40 PM   #12
BDavis's Avatar
Wiring and framing are most likely already there. Pull the vent and trim to inspect. Have the same with 2 AC
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 08-17-2016, 04:36 PM   #13
Was at dealer with same problem.
Salesman said to try blocking vents in the part of my trailer that was to cold and force air to other room, bedroo next time out tried it on the 90+ Texas sun... worked fine...
Travelingcarl is offline   Reply With Quote
Old 08-19-2016, 11:56 PM   #14
BEFUDDELED MEMBER
Just run romex from pre-wired vent down the duct to the desired vent where 2nd AC will be installed.
13,SUNSEEKER 3010
RETIRED / New Mexico
KZ5PZ - EXTRA -
Viet combat vet USNR
DAV, VFW, CCL. SASS
shooter2 is offline   Reply With Quote
Old 08-22-2016, 01:47 PM   #15
Thanks Shooter I like that idea.
2012 Doge 2500 4x4 Cummins stock
345QBQ
one wife,son and a daughter and 2 dogs
Eatern Shore is offline   Reply With Quote
Old 08-22-2016, 11:53 PM   #16
BEFUDDELED MEMBER
I install a 2nd ac in the front vent. It was not wired for 110. I ran the the romex back through the L ac duct to the bedroom vent where I could drill and run wire to front back corner of closet. Then down through floor of closet through floor, under floor to shore cable and to breaker box. I also purchased another buss bar for the breaker box and converted it to 50a. replaced 30a ac cable w/ 50a . replaced 30a transfer switch w 50a. Put the 2nd ac on one buss opposite original single buss so when operating on generator only 1 ac and all other circuits do not overload the 30a generator . After test drive had to secure romex as it bounced up and down while driving and making tapping noise. I went in through ac vents and put a spot of liquid nails to secure the wiring.
I did not put the A/C in the bedroom. Did that on my previous 5th wheel.It also short cycled as thermostat in same small room, even with the door open. Too loud in the small room, besides blowing you out of bed it also would cause frost bite on any exposed flesh.
13,SUNSEEKER 3010
KZ5PZ - EXTRA -
DAV, VFW, CCL. SASS
Old 08-23-2016, 06:07 AM   #17
TURBS's Avatar
Adding a second a/c to a 30 amp camper.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 08-23-2016, 04:17 PM   #18
BEFUDDELED MEMBER
first incarnation
http://www.forestriverforums.com/for...lbums2774.html
13,SUNSEEKER 3010
KZ5PZ - EXTRA -
DAV, VFW, CCL. SASS
Old 08-24-2016, 03:21 PM   #19
I once had a stand alone AC in the bedroom of a fiver.
It was 50 AMP. The AC in the living/kitchen area was a 15,000 BTU
and ducted. The bedroom unit was a stand alone not ducted. It
is off or on and when we had it on it was nosy. We didn't like it.
whj77372 is offline   Reply With Quote
Old 10-15-2016, 01:49 PM   #20
Just pulled the bedroom vent trim. Are these the wires needed for a 2nd a/c?
Kris & Alicia
B&W Companion Hitch
2012 Sierra 32QBBS
