Old 08-05-2016, 12:44 PM   #1
Adding a Second AC unit
Im not sure if I filled out my signature correctly, I have a Sand Piper 345QBQ.
The master bedroom gets really warm in the summer.
Im looking to add a second unit, I'm thinking of using a duct less unit, I would run the power supply from the breaker panel up the demising wall of the bedroom then use wire molding or make something to cover the wire on the ceiling. The pre wired location is in the front where the bunks are and that area is like a meat locker.
Has anyone done something like this? I have a construction background, but have limited knowledge of RV AC add on's.
Any help would be appreciated.
Eatern Shore is offline   Reply With Quote
Old 08-05-2016, 12:46 PM   #2
Do you have a 50 amp plugin?
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 08-05-2016, 12:51 PM   #3
Yes I do it was pre wired for two units but only came with one.
I just don't need the extra cooling in the front of the unit.
2012 Doge 2500 4x4 Cummins stock
345QBQ
one wife,son and a daughter and 2 dogs
Old 08-05-2016, 12:54 PM   #4
Then you should be good to go on adding.
Old 08-05-2016, 02:12 PM   #5
Telstar's Avatar
If you have a roof vent in the bedroom you can replace it with an air conditioner. It's fairly easy to run wire in the attic.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 08-05-2016, 02:44 PM   #6
Newly Retired
I would be concerned about framing to support the weight of the AC unit.
I have never added one to a camper but it seems like a logical concern.
Have you considered trying a circulating fan to push the cool air to the hot area?
If your luck is like mine cool weather will arrive as soon as you complete the installation.
Good luck with it.
Steveboe is offline   Reply With Quote
Old 08-05-2016, 02:45 PM   #7
I am curious about this too. My Sierra 32QBBS is prewired for a 2nd A/C unit in the front where the bunks are and it is a meat locker. However the rear bedroom is warmer than the rest of the camper. It is ducted a/c with ducts run into the rear bedroom and has a skylight. However, there it isn't prewired there. Mine also has 50 amp hook up.
Kris & Alicia
2001 Ford F250 CC LWB 4X4 PSD
B&W Companion Hitch
2012 Sierra 32QBBS
noslofivoh is offline   Reply With Quote
Old 08-05-2016, 03:53 PM   #8
jtatum65's Avatar
A/C Mod
Consider this A/C mod. Several have done it and are very happy with the results.
Increase ac vent air flow by 75%
Jim & Evelyn Tatum
2013 Rockwood 8289WS FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2016= 33
# of Campgrounds= 11
Nights Camped 2015= 31 @ 7 CG
jtatum65 is offline   Reply With Quote
Old 08-05-2016, 03:56 PM   #9
RiderBloke
RiderBloke's Avatar
I pulled all my ceiling vents in my trailer and found that with low quality cardboard ducting 2 had a space around the ceiling fitting into the ceiling area and the ducting went on past the last outlet to who knows where. I took some Duct tape and some cardboard and taped up the holes and ended the ducting right at the fitting. It seems to have added something to the airflow.
Also I intend to get into the unit on the roof (using a visiting son-in-law as the worker. ��) and do some efficiency work up there as in one of the forums. I also found that the piece of material separating inflow and outflow allowed too much air straight from out to in. Fixing these sorts of things makes a difference.
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
Old 08-05-2016, 03:58 PM   #10
Head Rambler
If your unit is prewired for the second A/C then the power wiring is already in the ceiling at the vent opening. Also, the bracing is already in place for it as well.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
