03-04-2018, 06:24 PM
USAF Retired
Adding exhaust vent to Georgetown
Our 2011has no external exhaust and we are wondering if anyone has made this modification to theirs. If so is there a kit we can get or just DIY?
03-04-2018, 06:52 PM
What are you trying to vent? Microwave, oven, washer/dryer? Are the ceiling vents/fans not enough? Please clarify.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
03-05-2018, 01:00 PM
USAF Retired
Exhaust vent
Sorry about that; didn't realize I had not fully explained myself. I want a vent above the stove to vent cooking heat. this is the first RV we have had that did not come with an external vent. Very bothersome in the summer months.
03-05-2018, 01:09 PM
I would love to do this to mine. I can't believe trailers come with hoods that vent into the living area. How hard is it while building to just vent out. I'm pretty sure most hoods come with the option of either way. Oh well, I'm also pretty sure I can't get my wife to let me cut a hole in the side out our trailer.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
03-06-2018, 04:59 PM
Stove vent
I had to install a vent on my Passport, the ceiling vent didn't work well and smoke detector kept going off. It is not an easy task and requires 2 people. The biggest problem is the vent cannot be located where the present vent is located due to the fact the vent flange won't reach the outer vent flange. Measure, remeasure and measure again. By the way the estimate from the RV shop was over $500.,they get $125. per. hr.
03-06-2018, 05:02 PM
Stove vent
I had to install a vent on my Passport, the ceiling vent didn't work well and smoke detector kept going off. It is not an easy task and requires 2 people. The biggest problem is the hood cannot be located where the present vent is located due to the fact the hood flange won't reach the outer vent flange. Measure, remeasure and measure again. By the way the estimate from the RV shop was over $500.,they get $125. per. hr.
03-06-2018, 05:12 PM
Remove 1 of these Posts! Youroo!!
03-06-2018, 05:30 PM
Kanadian Kamper
Peppercatt......
I’m going out on a limb and guess your previous RV(s) may have been trailers versus a motorhome. There’s a little story behind why MOST motorhomes don’t have a vent for the stove, and trailers do.
IF and I repeat....IF you were to forget to close the exterior clip on the stove vent of a trailer, the possibility of carbon monoxide buildup from the towing vehicle’s tailpipe could be strong enough to trigger the carbon monoxide monitor and sound the alarm. No harm no foul, because you’d hear it when you stopped and there’s no one allowed to ride inside a trailer. CO levels could be lethal but you’d know by the alarm.
If they had...and that’s IF they had a stove vent in a motorhome, and someone was to forget to close the exterior clip on the stove vent, people inside the motorhome while underway down the road, MIGHT start to be subjected to carbon monoxide at a gradual enough pace to cause CO poisoning without being at a level high enough to set off the alarm.
Sound reasonable?
Ken and Terry
03-06-2018, 05:31 PM
I have been installing range hoods and microwaves for 45 years in homes and trailers. It's not hard. Especially in a trailer. In a motorhome, all bets are off.
I'll be replacing the hood in my 5th wheel this summer. The hood comes with a flange. The wall cap has a flange. If they don't meet you simply add a metal extension between the too. Just check for wall studs, plumbing stacks.
03-06-2018, 06:12 PM
I too own a Georgetown with no wall-vent in the kitchen or over the stove.
I have a simple work-around:
I open the kitchen window about 1/4 inch and turn on the ceiling fan in the kitchen area. Works very well.
McCormickJim
2017 GT 31L5
03-06-2018, 07:58 PM
On my first post I used vent instead of hood, sorry it bothers you. I don't know how to remove it.
03-06-2018, 08:31 PM
Ease up there buttercup. Some people don't know how to do that. And after an unknown to me amount of time, that option goes away.
03-06-2018, 08:45 PM
FYI If the Edit button appears between thanks and quote, you can click on it and edit or remove your post. When it goes away you can't do anything with it.
03-08-2018, 12:45 AM
See the following thread. My installation discussion and pictorial is #27.
http://www.forestriverforums.com/for...or-125126.html
Also, after living with it a while, I wish that I had not installed the flapper vent valve that came with the microwave. It is very lightweight and flaps in the wind on a breezy day. The new exterior vent cover flapper would have been sufficient.
-Richard
-Richard
03-08-2018, 03:51 AM
-Richard
As an electrician, I have installed 100's of rear vent exhaust hoods. The flapper was the first thing to get thrown away.
03-08-2018, 07:12 AM
Georgia Rally Coordinator
Not a motor home but my V-lite did not come with a vent for the stove either. Problem solved as there was a vent right of stove and positioned about 4 ft from the wall. I installed a fantastic fan in this vent opening as it was also pre wired for a power fan. Mine has the automatic raise and lower cover when you start or stop fan. This solved mine problem.
Btw you have about 90 min to edit your post before that option goes away. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
