Old 08-22-2014, 05:19 AM   #1
adding hand rail
I just had leg taken off above the knee, and would like to add a handrail to my 2014 3010DS entry steps. These steps are higher than a regular staircase step, and a bit more difficult to use with crutches. Would feel a whole lot safer with a sturdy hand rail. I haven't done much looking at the MH to see about it, but I have noticed there doesn't seem to be too many sturdy attachment points. Any one ever done this or any ideas?
2014 Sunseeker 3010DS
With chocolate, all is well
richardwise is offline   Reply With Quote
Old 08-22-2014, 09:08 AM   #2
mark0224's Avatar
Put one on our old trailer but it was built like a brick **** house and there were solid places to connect it. Try looking in the door jamb where the lock goes in to see whats behind it, I think they are made to have them now so it shouldn't be a problem. The door should have a stud running up both sides metal or wood. Hope things go easy if you decide to do it yourself.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 08-22-2014, 11:59 AM   #3
Smile
Hi, had the same issue DW is a stroke survivor and left side affected. Going into the coach with a cain works for her but getting out was difficult, I removed the flip up table and added a grab bar to the door frame to assist in getting her out of the coach. Bought one from camping world. There is no good spot that i found on the right side of the coach entry. Hope post makes some sense.
rekwiat is offline   Reply With Quote
Old 08-22-2014, 12:25 PM   #4
Witch Doctor's Avatar
Sorry to hear that first of all. About a month ago there was a post with pictures that is an addon that has lowers the steps and had 2 hand rails if I remember right, maybe someone will know the name. Also good for you still getting out there camping.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-22-2014, 01:12 PM   #5
Steps for Mini-Lite TT
I just ordered steps for my Mini-Lite TT. Here is there e mail. info@rv-co.com
There is also a telephone number. 214-649-9407. After placing the order it will take about 6 weeks to get the unit.
Robert
robert elling is offline   Reply With Quote
Old 08-22-2014, 01:53 PM   #6
I just looked at the Lend-a-Hand hand rail Camping World has. That may work by mounting on inside of door frame, will have to hold a lot of weight though. I thought about mounting a support bracket on the floor at top of steps to hold an upright post and lower end of rail bracketed to door frame. Something to think about for a while, I guess.
Old 08-22-2014, 02:11 PM   #7
Brother Les's Avatar
will this help?
Brother Les
Old 08-22-2014, 02:17 PM   #8
mark0224's Avatar
Amazon.com: Stromberg Carlson (AM-200) Lend-A-Hand White Assist Handle with Foam Grip: Automotive
Found this on Amazon $34.66.
If you want to beef it up you could make a plate that would go on the inside of the trailer and bolt right through the wall use a good hardwood like oak.
Old 08-22-2014, 03:12 PM   #9
Brother Les- that's what I was looking at. It may work if I have have enough room on inside of MH, no steps on outside, all on inside of door. Hoping to add something like in a house. Using stairs as an amputee, you use one crutch and the hand rail. I have seen videos of people not using handrail, but they look like they have years of practice, I've only had a couple of days. But, I'll get there. Right now, sitting around the house in a wheel chair is boring.
Old 08-22-2014, 06:21 PM   #10
dap
Camping World has a telescoping hand rail Cat#69346 that maybe you can adapt for your use.Sorry that I don't have a picture.
Hope you find something that will work.
dap is offline   Reply With Quote
