Old 08-19-2014, 07:33 PM   #1
2014 XLR 27HFS
dave961's Avatar
Adding Outlets
In the living area, changed a double 110 outlet to a single + 2 USB charging ports (shore power). In the garage, added a 3in1 meter (time, temp, & DC volts) plus unit that has two 12v DC outlets (camper came with none) and two USB charging outlets (from battery). Also changed all interior bulbs to LED.
Name:	USB Outlet1.jpg
ID:	60962   Click image for larger version
Name:	3in1 Guage (2).jpg
ID:	60963   Click image for larger version
Name:	Guage & 12v Outlet1.jpg
ID:	60964   Click image for larger version
Name:	12v Outlet with USB (2).jpg
ID:	60965   Click image for larger version
Name:	LED Bulbs1.jpg
Name:	3in1 Guage.jpg
ID:	60967   Click image for larger version
Name:	12v Outlet with USB.jpg
Dave & Audrey
dave961 is offline   Reply With Quote
Old 08-19-2014, 10:29 PM   #2
I like it. I've been looking for a standard 110v single outlet that also has a 12v outlet in the same housing, but with separate power feeds.
wickedwyrm is offline   Reply With Quote
Old 08-20-2014, 12:40 PM   #3
Did you take power from the feed to the 12v switch for the USB 12v lighter outlets?
atschneid is offline   Reply With Quote
Old 08-20-2014, 06:44 PM   #4
2014 XLR 27HFS
dave961's Avatar
Yes, I tapped into the 15a hot line going into the (far right) light switch that doesn't seem to do anything. The 12v outlet housing also has a 15a fuse in the back of it.
I wanted to be able to charge my phone whether on DC or AC. That's why I put in both types of outlets.
Dave & Audrey
Old 08-20-2014, 06:50 PM   #5
2014 XLR 27HFS
dave961's Avatar
They aren't separate power feeds, only 110 going to the unit. The USB ports are converted to DC and auto detect how much the charging device needs.
Name:	12v Outlet with USB 3.jpg
Dave & Audrey
Old 08-20-2014, 08:26 PM   #6
Thanks, it a great idea, I am going to do the same thing. You validated what I was thinking of doing with the light switch above our bed. I need 12 volt outlet to run a converter for my cpap machine witch draws hardly anything. Thanks for the feedback
electric, xlr, modifications, electrical
