Old 05-24-2016, 06:34 PM   #11
I misread your original post. Forget what I just said. Lol. Next time I'll read more carefully.
medicron is offline   Reply With Quote
Old 05-24-2016, 06:45 PM   #12
Carknocker Family
Ida Ratherbe Camping's Avatar
Looking at your model on the web. Says it is cable TV ready in living room only. Still looking for pics though.
Ida Ratherbe Camping is online now   Reply With Quote
Old 05-26-2016, 12:31 PM   #13
I meant to take a picture but I did take the wall plate off and the only coax connection is for the antenna. The cable and TV2 jacks on the back were not connected to anything. The SAT jack wasn't connected to anything.
Harveyfamily is offline   Reply With Quote
Old 05-26-2016, 06:06 PM   #14
DaveSchwartz's Avatar
Okay, so the booster on the wall does only the antenna (which is coming down from the roof inside the wall) and when the booster is on, the signal comes out the TV1 connector on the front to your television. Usually, when you have an external 'cable' connection, it is attached to the 'cable' port on the back of the booster and that's the signal that comes out TV1 (and TV2, which is the same as TV1 on the front panel, via an internal splitter - intended to run inside the wall to a second TV placement, such as a bedroom, which your unit doesn't have so the cable isn't even there) when the booster is off.
I got the impression that you found an exterior coax port somewhere... Where does that come out on the inside?
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-28-2016, 08:32 PM   #15
Got the outside coax plate/Jack from Amazon. For those that have this from the factory: I noticed this cover has 3 screw holes. Is there a back plate that this is screwed into?
Old 06-27-2016, 10:01 AM   #16
Same RV, same question
Wildwood 195BH with the dual coax wall plate and can't find the external coax connection.
namzaps is offline   Reply With Quote
Old 07-07-2016, 12:39 PM   #17
Face plate is confusing
OK, I removed the coax plate an sure enough the top port is not connected on the back side, which explains why I could never find an exterior cable connection. The bottom one connects to the antenna and booster.
