Old 07-06-2016, 05:59 AM   #11
I've been thinking of doing this. Where did you get you power from?? I don't have a plug in my storage area.
Wowens79 is offline   Reply With Quote
Old 07-06-2016, 08:32 AM   #12
mstell2's Avatar
I did have a plug so it was very easy to do. I'm no electrician but you might be able to run an outlet from the panel if you have space for another breaker. Or tie into an outlet close by.
mstell2 is offline   Reply With Quote
Old 07-06-2016, 07:46 PM   #13
Hvacman's Avatar
Same here with the plug. I had one already convenient I could use.
mstell2 is correct regarding adding a receptical. Its not difficult as long as you can find access to your panel or junction from another receptical that won't have much load on it. Just don't cut any corners when it comes to adding another electrical circuit. safety safety safety....
Hvacman is offline   Reply With Quote
Old 07-06-2016, 08:12 PM   #14
M109Rrider's Avatar
I added a receptacle in the basement for mine. Used a drywall box from Home Depot mounted through the false wall and daisy chained it off the outside receptacle 10 inches away
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
refrigerator
