Old 04-19-2011, 01:08 PM   #1
Adding shelves in kitchen cabinets
i am trying to put additional shelves in some of the kitchen cabinets. But can't decide how to attach to sidewalls.
Any suggestioins.
Thanks Tincup
Tincup is offline   Reply With Quote
Old 04-19-2011, 02:55 PM   #2
Glue vertical supports to the side walls,go from the bottom shelf to the underside of the upper(new) shelf. Use thicker material than the Fac. use for the upper shelf bottoms,no dippy do. Youroo!!
Old 04-19-2011, 05:22 PM   #3
Dave_Monica's Avatar
You could also use free-standing wire shelves/stands instead of the added shelves. We found them at WalMart.
Dave
Old 04-19-2011, 06:21 PM   #4
KyDan's Avatar
Dave
Us too.
Stack-able wire baskets from WalMart or your favorite
kitchen goodies store.
Old 04-20-2011, 05:43 PM   #5
Danimal's Avatar
i used culk and some brad nails just long enough to hold in place until the culk dries
dont go to long with the brads because you never know whats on the other side of the wall
2005 Dodge Ram
2011 Rockwood 8281SS
Danimal is offline   Reply With Quote
Old 04-20-2011, 06:43 PM   #6
backin15's Avatar
I am not sure what you call them but I used some metal strips with slots in them that you can cut to length. You can get them at Home Depot or Menards. You then buy a bag of clips that fit into the slots. The clips support the shelving. In the clip bag are screws you can use to fasten the clips to the cabinetry. The screws are short and if it is easier you can screw them to the wall of the camper. Buy a piece of Filon or thin plywood and cut to size. I used this meathod in my last camper as well as my Flagstaff and never had a problem. The other advantage is the shelves are adjustable.
backin15 is offline   Reply With Quote
Old 04-21-2011, 08:54 PM   #7
cheese53073's Avatar
I'll second the shelf sandards and clips. use quality 1/2 plywood for the shelves and you'll be fine.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 04-27-2011, 10:20 PM   #8
seven_campers's Avatar
Anyone have pictures of your shelve mods (e.g. kitchen, pantry, overheads)? We just brought home a 2009 32 BHTS and will probably remove the lazy susan in kitchen and replace with shelves. Also, thinking of adding additional shelves in the pantry area...
Thanks!
Mike
Mike & Joelle + 5
2008 Dodge 3500 CTD, MC, 4x4, SRW,
2009 Sabre 32 BHTS
seven_campers is offline   Reply With Quote
Old 04-28-2011, 06:13 AM   #9
here are a few pictures of my kitchen mods.
ID:	5477   Click image for larger version
ID:	5478   Click image for larger version
ID:	5479   Click image for larger version
ID:	5480   Click image for larger version
skidoonut is offline   Reply With Quote
Old 04-28-2011, 07:01 AM   #10
I added shelves to one of our closets in our 374ts. I was able to use a stub finder with a electrical indicator to find the aluminium studs in the wall to attatch 1x3's to the walls. I then set shelves on top and used a brad nailer to lock them in place, and a few screws to hold tight. Depending on how much room you have in your cabinets, or how much space your willing to loose? You can get a few peices of oak or pine and cut side peices to fit in, then set your self on to them and use a couple brads to hold them in. Basically a shelf with legs. You may also be able to pick up a few small metal shelf bracket pins or adjustable shelf brackets, (attatched link, and last photo). Just use a drill with a depth setter to drill the holes for the cabinet pins, a little glue on the pins, and compression will hold the shelves in place. You can buy the cabinet shelf pins, (last picture), for a dollar or two at just about any home center.
JR Products
ID:	5482   Click image for larger version
ID:	5483   Click image for larger version
ID:	5484   Click image for larger version
GrowingGoatee is offline   Reply With Quote
