Old 05-11-2016, 10:35 PM   #1
Adding skylight above shower
I have a 261BHXL, and ours did not come with the skylight above the shower that I see on different/newer models.
I'm tall, and that extra space would be great. Wondering if anyone has added this and how difficult of an addition is it? Would appreciate if anyone could point me in the right direction. Which part it is, etc. I imagine install isn't difficult. Cut a hole, screws and caulking?
BNBRV is offline   Reply With Quote
Old 05-11-2016, 11:00 PM   #2
I never added one but I did replace a hail damaged one on my last camper.
I don't think adding would would be a big deal. Just make sure you measure and cut carefully. Be careful that the manufacturer didn't run wire or plumbing in the ceiling above the shower.
I personally think installing a new one is much easier than replacing an existing one....scraping Dicor and butyl tape was a pain.
Skyliner is offline   Reply With Quote
Old 05-12-2016, 06:20 AM   #3
Do you know if they sell them as a kit with some sort of instructions? I'm not sure what/where to buy it.
Old 05-12-2016, 07:51 AM   #4
Don't Camp Enough
DSMURPHY's Avatar
Amazon and e-bay has them. Also try Replacement RV Parts & Fender Skirts - AC Shrouds & more - IconDirect.com
You will enjoy this mod!
'2016 Rockwood 8288WSA
'2010 Tundra
DSMURPHY is offline   Reply With Quote
Old 05-12-2016, 08:33 AM   #5
Go figure, Amazon "RV Skylight" - plenty of options. Much appreciated
Old 05-12-2016, 08:52 AM   #6
i wouldn't fit in my shower without the skylight. The top of my head is literally in the skylight
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 05-12-2016, 09:07 AM   #7
I have to bend my head down slightly. It's not ideal, hence the skylight. Looking forward to this upgrade. Otherwise it's really a great little camper.
Old 05-12-2016, 11:45 AM   #8
Be careful. Most of what you find when you google RV skylight are replacement outer domes.
You need a complete kit that includes inner dome, garnish, outer dome, plus screws. In addition, butye tape or innersealant (use sealant recommend by manufacturer, DICOR was not recommend for my install-outgas from sealant could have fogged the plastic), outer sealant and eternabond tape for last lasyer of outer sealing.
RV Skylights, Outer, Clear Inner Dome Skylight, White Inner Garnish
Our camper had hail damage so we replaced both the inner and outer domes. We kept and used the original garnish since it matched the other garnishes in color. In case you don't know, garnish is the trim around the inner dome that covers edges up and masks the sides of the hole cut in the ceiling. Make sure your garnish is deep enough to go thru and mask the sides of the ceiling hole. When we replaced an RV vent last year, the stock garnish was too shallow and we could see the foam component in the composite roof. The original garnish that was deep enough wasn't compatible with the new rv vent.
Good luck, it isn't a hard job. I would use an oscillating multi-function power tool to cut the hole instead of a jig saw or circular saw. With the oscillating power tool, you can be very deliberate in cutting the hold and go very slow to ensure you aren't cutting into any roof beam structures, wiring, or plumbing.
Old 05-12-2016, 01:35 PM   #9
Good info. I may just have someone handle it for me at a dealer.
Old 05-12-2016, 07:22 PM   #10
You can purchase the inner and outer domes from Icon at "icon.com" be sure to order the special roof sealer. Dicor and other sealers do not adhear to the lexan domes. I can tell you from experience.
hillsdaletc is offline   Reply With Quote
light, show, shower
