Old 04-05-2012, 10:33 AM   #1
Newbie
pg_rider's Avatar
Adding wire shelves to my pantry -- any tips on screwing brackets into wall?
I'm going to add these wire shelves to the pantry and bedside closets in my Rockwood 2306:
I need to screw the vertical supports along the back into the wall -- any suggestions on what to use for screws? Just a basic wood screw? How long (I assume that I don't want to go too deep)?
Thanks!
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 04-05-2012, 10:43 AM   #2
Herk7769's Avatar
Here are some fasteners I found to be awesome. They are pricey, but with the thin plywood veneer and Styrofoam core, pull outs and veneer crushing is a real issue with most wall fasteners.
The World's Strongest Fasteners and Fixtures - Wingits Innovations
HAM CALLSIGN - KC3FFW
Old 04-05-2012, 11:54 AM   #3
Newbie
pg_rider's Avatar
Cool -- those look like the right solution. Home Depot sells them -- any suggestion on which ones to use?
2012 Rockwood 2306
Old 04-05-2012, 11:56 AM   #4
Newbie
pg_rider's Avatar
Rats, never mind -- just noticed those are all online-only. I need to get something today, so I'll look for whatever anchors they carry in the store. Thanks anyway!
2012 Rockwood 2306
Old 04-05-2012, 12:40 PM   #5
Herk7769's Avatar
The web site says they carry the brand (not sure what sizes) at the Home Depot store. The walls are about 1 1/2 inch thick so I would look for no more than a 1 inch anchor.
You want to spread that load over as big an area behind the wall luan as possible. That wood is pretty thin.
Old 04-05-2012, 12:52 PM   #6
Looks great. Think of all the bungy cords you could tie down stuff with now....
If it were me, I'd at least locate the wall studs and screw into something solid. A stud finder works through the thin plywood. Or use a hammer a lightly tap the wall until it feels solid. The studs should be "sort of" around 15-16" but they seem to vary somewhat and sometimes they are doubled up too.
If you can't locate studs or they aren't in an appropriate location, you could use those wingback anchor thingies. They are several types to choose from.
There are supports available for the ends of wire basket but 'course they won't work since your shelving is inverted. If you have 3/4" sidewalls, you could attach a 1x1" cleat.
On screw length, look for one that is used to fasten a piece of 1x1" to a wall and re&re it and see what length that is. Use at least a #8 screw and if possible a #10 in the upright for more holding power.
Maybe you should tie the shelving to the arms with tie-wraps?
myredracer is offline   Reply With Quote
Old 04-06-2012, 10:37 AM   #7
Bennington Camper's Avatar
I've bought them at a local HD before.
Used them to hang a couple of flat panel TV's in offices on drywall.
Glenn
Glenn - KA2DTH
2007 Chevy Express 1500 AWD
2005 Surveyor SV-230
Bennington Camper is offline   Reply With Quote
Old 04-22-2012, 09:20 PM   #8
Canadian Member
itat's Avatar
I'm looking to add those shelves in the wardrobe on my Roo 23SS.
I'm thinking of adding an extra 1/4" thickness of wallboard, glued with construction adhesive to the back wall of the wardrobe to improve the stiffness of the wall, then screwing in the wall brackets with #10 screws. I tried my stud finder and could only find 1 stud for the entire width of the wardrobe.
Should I still use the winged anchors? The only anchors close to the Wingits at our local (Canadian) HD are too long.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-22-2012, 10:02 PM   #9
Newbie
pg_rider's Avatar
I ended up just screwing directly into the wall. Added shelves to my Rockwood 2306
So far so good, but the real test will be when they're fully loaded up and I go down the road with them. I'll be sure to report any issues I come across, but I'm confident they're going to be strong enough.
Note: my supports are resting on the base of the cabinet, so all the screws have to do is hold the supports against the back wall. The screws themselves aren't really bearing much load...
2012 Rockwood 2306
