Old 03-19-2012, 11:16 AM   #11
TURBS's Avatar
I do have pics but won't be able to post them till tonight.
As an update we went camping this weekend and ran the air with no issues.
Old 03-27-2012, 09:51 PM   #12
DesertDog's Avatar
Would love to see the pics too, as I have the same A/C unit in my Wildwood.
DesertDog is offline   Reply With Quote
Old 03-28-2012, 05:03 PM   #13
TURBS's Avatar
I am having a tough time getting to my unit to take pictures .
but it is as simple as this ..
I took off the cover to my thermostat and then locate which wire says "fan" on it .
mine was orange and about a 18-22 gauge wire very small such as phone wiring.
then I took off the filter trim panel on the inside of the camper and removed the filter .
on the right hand side of the unit you will find the same 22 gauge "orange" on mine
I simply cut the wire and put on a female spade connector on each end that I cut and then plugged them into my delay module .
then I proceeded to adjust control know till I had about a 5 second delay .
then mounted control box back into a/c area .
Done .
in the next few days I will attemet to get in there and take pictures .
heres one of the orange wire and thermostat. wire in question is on the far right and is simply labeled "fan" thats the wire you are looking for in the a/c unit
Name:	2012-03-12 17.01.03.jpg
Old 03-28-2012, 05:21 PM   #14
Herk7769's Avatar
Originally Posted by f1100turbo View Post
Herk?
don't look at me.
I am learning at the knee of the master!
Still waiting for the wind to die down to install my awning remote.
HAM CALLSIGN - KC3FFW
Old 03-28-2012, 05:25 PM   #15
TURBS's Avatar
hella windy as of late !
IVE since figured it out from when I "herked ya"
post 14 on has the corrected simple answer to make this work !
Old 06-15-2012, 09:34 PM   #16
DougP47's Avatar
About the thermostat I would like to replace mine with a digital and part# please. My next mod is to replace the bumper that came with the Salam. I cannot even cart a rack on the back without it twisting. Going to 3/18 wall and I might even cap it to make it even stronger
DougP47 is offline   Reply With Quote
Old 07-24-2012, 03:24 PM   #17
ILUVRVing's Avatar
Did you end up splicing back the blue wire back together on the delay, now that your using it on the 12VDC side?
Sorry - just tailing / searching the forum - I have a 2006 Cherokee 305B 5er w/ a Duo therm AC that just started having AC start up issues. After a trip from VA last week that was in the mid to upper 90's. The AC would run all day, then @ night, when it finally reached the stat set temp the AC would shut off, BUT then on start up would blow the 20amp AC breaker. I'm looking to do this mod, as well as add (replace~I think) the start up cap to a Supco Mfg. - SPP6 - Hard Start Capacitor.
Marge: Homer, is this how you pictured married life?
Homer: Yeah, pretty much, except we drove around in a van solving mysteries.
My album; past and present projects:http://www.flickr.com/photos/9617164...7600656468619/
ILUVRVing is offline   Reply With Quote
Old 07-24-2012, 09:55 PM   #18
Great Horned Owl's Avatar
Originally Posted by JFM-jr View Post
7K watts and shes huffin a bit on ya? Yeesh I sure hope my twin 2K Hondas are up to the task for my 13.5K unit. This will be my first year with them.
It should work for you. I am using twin 2K Champions that have specs very similar to the Hondas. They run the AC fine on low fan. On high fan, they bog down.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 07-24-2012, 10:09 PM   #19
You'll have now problem running your 13500 hth A/C with the two twin 2000 watt Hondas. We are running our 15000 hth A/C with our same setup and have power left over for other devices. I wouldn't try to run the A/C, the coffee pot, the water heater, and the microwave at the same time however.
Harry
grb2980 is offline   Reply With Quote
Old 09-18-2012, 07:24 AM   #20
I ran my 13.5 off a Honda eu3000is all day long in 95 degree weather this summer. I leave fan running and gen in eco mode. Spins up as soon as compressor starts. I suspect maybe my ac has a soft start capacitor? I do also run the gen on super unleaded.
TV: 2012 Silverado 3500HD DRW Duramax/Allison
FW: 2013 Sandpiper 365SAQ
fschambe is offline   Reply With Quote
air conditioner
