Old 07-30-2013, 02:20 PM   #31
campfirefun's Avatar
I should clarify the little wire on the delay unit between the post
campfirefun is offline   Reply With Quote
Old 07-30-2013, 02:29 PM   #32
TURBS's Avatar
Yep knew what u were talking about.
I just can't remember if I cut it when I had it on 120v or if I cut it for 12v side.
I believe you cut it for 120v.
So leave it for 12v side.
Hopefully someone will chime in "herk"
I won't be able to tell you till I get home.
Doesn't it say cut wire for " x " voltage?
Turbs
Old 07-31-2013, 03:55 PM   #33
Herk7769's Avatar
Leave it alone if you are switching the fan wire from the thermostat.
(12 volts)
HAM CALLSIGN - KC3FFW
Old 07-31-2013, 03:59 PM   #34
TURBS's Avatar
(12 volts)
Old 07-31-2013, 04:18 PM   #35
gonecampin
gonecampin's Avatar
Originally Posted by Great Horned Owl View Post
It should work for you. I am using twin 2K Champions that have specs very similar to the Hondas. They run the AC fine on low fan. On high fan, they bog down.
Joel
I have a crusader 295 with a 15000 a/c and my 2 2kw Honda's run my a/c just fine even on hi fan.
Randy & Jeanette Feller
2013 PT Crusader 295 RST TE C
2012 GMC 2500 Denali Duramax
Kalispell, MT
gonecampin is offline   Reply With Quote
Old 08-01-2013, 04:02 PM   #36
Tom Wolf's Avatar
My 3000 Honda generator will not keep my Rockwood 2608WS with a 15000 A/C unit running. I can go about 30 minutes before it goes to over load on the generator. Is this normal? Or should I look at what you have done to your trailer?
Tom
2013 Rockwood 2608WS
2003 Chevy 2500 HD Crew-cab D-max
2 Honda 2000 generator's
Tom Wolf is offline   Reply With Quote
Old 08-01-2013, 04:10 PM   #37
TURBS's Avatar
Tom
My mod only helps with starting not running.
You have at best 25 amps to work with.
A/c is going to be pushing 15+
Fridge on gas?
Wh on gas?
Converter draws 2-8 amps
Read this chart.
normal appliance amp draws
Old 08-02-2013, 03:45 PM   #38
Update with yamaha 2000. I could not get the ac to work. The yamaha went to overload mode. I played with the fuses and shut down all but the ac. i do not know the size of my air unit but I'm guessing its on the bigger size. I was able to get the ac to kick on plugged into a regular outlet with my heavy duty cord and adapter in my garage. That has never worked. The delay is about 3-4 seconds. I could not get any longer delay without going over 1 min. I left the delay hooked up as maybe one day I can get a second yamaha and parallel two 2000 for 4000 wats. I figure it can't hurt to delay the fan a few seconds
Old 08-02-2013, 03:48 PM   #39
TURBS's Avatar
Mine runs 8- 10 seconds
Old 02-08-2016, 09:47 AM   #40
TURBS's Avatar
air conditioner for generator mod
Picked up two delays today for my new Columbus.
$12.73 each.
Now for warmer weather.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
air conditioner
