Old 04-19-2012, 09:45 PM   #1
shooted's Avatar
Air Conditioner Sealing, Done
I finally got around to sealing up the air conditioning. Nothing new here, everybody knows exactly what I found when removing the cover. If you didn't know better you might think the manufactures of rv's think tape is a structural building material. Despite all the tape, there was still gaping holes into the attic. I expected to find that. What I did not expect to find was the partition between the supply and return not in place and laying essentially on it's side! The supply and return was entirely open to one another! The only thing meant to hold it in place, you guessed it, foam tape. It appears this is meant to be easily adjustable up and down when adjusting the tension on the gasket bolts.
I found flashing material was easy for me to score, break, and bend by hand. I installed this around the entire perimeter with staples and folded into each duct, then taped accordingly. I even used flashing to seperate between the supply and return.
Air flow has increased dramatically and the unit even seems quieter now.
shooted is offline   Reply With Quote
Old 04-19-2012, 09:54 PM   #2
Drinkin beer on the beach
Rod Johnson's Avatar
Nice catch.
I was a little dissappointed in the way my furnace ducts were attached to the plenum. I think a tape sealing job should get me fixed up pretty easily.
I haven't run my AC other than to make sure it turned on...
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
air conditioner, sealing, furnace
