Old 08-23-2015, 08:04 PM   #1
2006 Georgetown 340
Allure flooring.....
So I have read about 100 threads on allure and other wood flooring upgrades. Each reviews how it was installed and how it looks after. What I cannot find is information about slides and whether they will slide over the new floor and basically raise up without any issue. The current laminate the slides in the kitchen rolls right across. If I add 1/8 inch to 1/4 inch will the slide be out of adjustment?
Thanks in advance....
compint is offline   Reply With Quote
Old 08-31-2015, 03:36 PM   #2
fields's Avatar
laminate flooring
Before I put my flooring in my travel trailer I tested a few pieces. Pulled the slide in and out several times. They ever moved and were not scratched. I bought the thinnest laminate I could find at Lowes. The hardest part of the project was cutting around all the angles and nothing in that camper was square.
fields is offline   Reply With Quote
Old 09-02-2015, 08:13 AM   #3
etothepii's Avatar
Doesn't this upgrade add a lot of weight to the rv?
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 09-06-2015, 08:02 PM   #4
2006 Georgetown 340
Somewhat. I don't think it would add a lot though.
flooring
