Old 08-15-2017, 12:57 PM   #1
Alternates to this flip down rack..
I really wanted this rack for our new Arctic Wolf, however after talking with Lippert it sounds like it won't fit. The body of the camper over hangs the main frame by a couple inches, thus reducing the exposed secondary frame that the bumper mounts to, which according to Lipperts needs to be at least 3.75" exposed.
So i can either still buy this one and do some modifications to their bracket (with safety in mind) or find a different rack. I would prefer to have the rack mount to that secondary frame vs. buying a receiver hitch assembly that mounts to the 3rd frame on my camper.
Any ideas?
-2018 Arctic Wolf 265dbh8
-2017 Chevrolet Silverado 3500 High Country
SOLD-2015 Chevrolet Silverado 1500 w/ Max Trailering Package
willie1280 is offline   Reply With Quote
Old 08-15-2017, 12:59 PM   #2
Photo showing the main frame, secondary and third frame.
Old 08-15-2017, 01:04 PM   #3
Wobbles's Avatar
I have seen that rack advertised on units for sale. Check the FR brochure for bicycle rack.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 08-15-2017, 01:05 PM   #4
Wobbles's Avatar
It goes over the bumper primarily
Bob & Michelle
Old 08-15-2017, 02:18 PM   #5
I know what it is, where to buy it, etc.....the problem is it won't fit because not all Forrest River campers and Lippert built frames are identical and made for it.
So the question is, do i modify it to work, or are there others similar (non-lippert) racks out there?
Old 08-15-2017, 02:57 PM   #6
Wobbles's Avatar
Ok, I did see it available for the Artic Wolf in the FR brochure when I was shopping them.
Good luck in your search.
Bob & Michelle
Old 08-15-2017, 03:23 PM   #7
ben31's Avatar
I asked LCI (Lippert) which model fit my Crusader. They sent me a model number and it appears to mount on the tubing directly behind the bumper. Get on their site and contact them. They will ask for your frame serial number and they will then tell you which model will fit. BTW, you will need to move your spare tire.
https://www.lci1.com/contact
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 08-15-2017, 03:26 PM   #8
I did this, and that's how i came up the conclusion i'm at with that rack.
The frame number tells them which rack of theirs (Lippert) will fit on the frame they built. However, once the frame leaves them, they can't control what happens with the body. So in my case, the body is slightly longer than the main frame, therefor the rack won't fit.
Old 08-16-2017, 02:43 PM   #9
Capt. Mike's Avatar
If you order the rack as a factory-installed option when the trailer is built, they use a slightly longer frame to allow about 5 inches to stick out behind the body, and mount the rack to the extended frame rails. Without that option, the rails aren't long enough to accommodate the bike rack as an after-build option. You would be better off to go with a receiver welded to your frame under the trailer body.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 08-16-2017, 03:23 PM   #10
I don't care for the receivers because of the bounce/sway they get because of everything pivoting on the single square receiver.
Old 08-16-2017, 09:08 PM   #11
willie1280 ~ do you have any welding/fabrication shops in your area?? If so, take your rig and a picture of this rack over and talk to them. Ask about installing square tubing strengthened with 'fish plate'. With that question, they should be able to help manufacture what you need.
Good Luck ~~
extxn is offline   Reply With Quote
Old 09-05-2017, 11:47 PM   #12
spaach's Avatar
I recently ordered this rack on a whim from ppl. Our 5th wheel bumper is welded right to the end of the frame rails. I plan to cut the bumper off the frame, weld extensions like yours but longer onto the bumper and frame. Then it's no problem to put the rack on. What you have going on would be some quick work for a fab shop.
spaach is offline   Reply With Quote
Old 09-06-2017, 08:46 AM   #13
I saw a rack at Walmart that I can install hitch at the back of my Cedar Creek, what I plan on doing is keep the rack in back of my truck. I want to sit the Honda's on the rack when I don't have hookups at the back of camper that way the Honda's will be off the ground. I don't want the Honda's in the back of Silverado as my bedroom is there and I can hear the Honda's, at the back of camper I can't hear them
spock123 is offline   Reply With Quote
