Old 09-18-2019, 06:28 AM   #1
Amp/Wattage Converter
I bought a used 19' power awning to install on my deck. What amp/wattage converter do I need to run off my house? I believe they are fused at 15 amp when installed on an RV, does that hold true for household AC as well. I've found one on Amazon, Schumacher brand which is well known for battery chargers 15A/200W for $45. Thanks
DLinMI is offline   Reply With Quote
Old 09-18-2019, 06:39 AM   #2
Ohms law
P=E*I
P is watts
E is volts
I is amps
Trksr is offline   Reply With Quote
Old 09-18-2019, 08:19 AM   #3
why worry about watts? if it is fused for 15 amps in the rv @ 12 vdc supplying anything more than that is overkill. so if the charger you mentioned supplies 15 amps @ 12 vdc that would be sufficient.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 09-18-2019, 12:57 PM   #4
Rather than a battery charger I'd opt for a power supply like one of these:
https://www.amazon.com/LEDwholesalers-Power-Adapter-5-5x2-5mm-3262-12V/dp/B074GGMD5J/ref=asc_df_B074GGMD5J/?tag=hyprod-20&linkCode=df0&hvadid=198076677096&hvpos=1o3&hvne tw=g&hvrand=10020136702021743886&hvpone=&hvptwo=&h vqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033389 &hvtargid=aud-801657747996la-354053952603&psc=1
More compact than a battery charger but still delivers 12V @ 20 amp. Cost: $40
Might even check out your local "Geek Shop" that repairs computers. They may have a power supply like this lying around. Just make sure it's a 12 volt unit.
You can also use one of these:
https://www.amazon.com/ALITOVE-Trans.../dp/B078RZ6C3N
Cost: $18
Both provide 12 volts and plenty of current to power an awning. When mine operates the motor draws around 6 amp as shown on my Battery Monitor.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-18-2019, 01:06 PM   #5
P=E*I What does * mean? https://www.amazon.com/gp/r.html?C=1...7240_435795930 I was looking at this
Old 09-18-2019, 01:14 PM   #6
Mr. Dan's Avatar
In a mathematical equation, it means "times" or "X" or "multiplied by".
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-18-2019, 04:17 PM   #7
Seems expensive considering there are less expensive units that will do the same thing.
2004 Nissan Titan
converter
