I needed a storage area for my sewer hose on my Crusader and I wanted a clean look here is what I came up with.
I knew I wanted at least 5 inches so I could store my graduated adapter end so I settled on 6" PVC pipe and found this product Buyers Conduit Carrier Kit, Model# CC600 (Found on Norther Tool for $54.99 with a discount code).
Here is what it comes with.
I then purchased a 10' piece of 6" PVC pipe (about $23.99 at Home Depot).
I cut the PVC to 74" (I should have gone long as I could for more storage but at the time it looked good and tucked away) and painted it black.
I had to make a spacer for the one side because of the LP line, I used a few pieces of 1/8 aluminum flat stock and stacked them.
I then clamped the saddle bracket to the frame and drilled the holes for the "U" bolts.
I mounted PVC pipe slid the end caps on and tightened the "U" bolts. Then secure the end caps with stainless self taping screws on the end cap side and I used button bolts on the access side so nothing would snag when sliding out.
Then I picked up a piece of plastic gutter and cut it to size so everything can slide out easily.
I put a carabiner just for added security that the cap won't open but also a lock can be used.
I also plan on drilling a few small holes in the bottom for drainage and ventilation.
Done! Total project time was about 4 hours and cost under $100 with miscellaneous little nuts bolts and paint.
