Old 05-06-2015, 09:20 AM   #1
NJCrusader's Avatar
Another Sewer Hose Storage Mod
I needed a storage area for my sewer hose on my Crusader and I wanted a clean look here is what I came up with.
I knew I wanted at least 5 inches so I could store my graduated adapter end so I settled on 6" PVC pipe and found this product Buyers Conduit Carrier Kit, Model# CC600 (Found on Norther Tool for $54.99 with a discount code).
Here is what it comes with.
I then purchased a 10' piece of 6" PVC pipe (about $23.99 at Home Depot).
I cut the PVC to 74" (I should have gone long as I could for more storage but at the time it looked good and tucked away) and painted it black.
I had to make a spacer for the one side because of the LP line, I used a few pieces of 1/8 aluminum flat stock and stacked them.
I then clamped the saddle bracket to the frame and drilled the holes for the "U" bolts.
I mounted PVC pipe slid the end caps on and tightened the "U" bolts. Then secure the end caps with stainless self taping screws on the end cap side and I used button bolts on the access side so nothing would snag when sliding out.
Then I picked up a piece of plastic gutter and cut it to size so everything can slide out easily.
I put a carabiner just for added security that the cap won't open but also a lock can be used.
I also plan on drilling a few small holes in the bottom for drainage and ventilation.
Done! Total project time was about 4 hours and cost under $100 with miscellaneous little nuts bolts and paint.
2015 Crusader 335BHS
2007 Chevy 2500 Classic Duramax
NJCrusader is offline   Reply With Quote
Old 05-06-2015, 09:24 AM   #2
Iwannacamp's Avatar
beautiful
Old 05-06-2015, 09:26 AM   #3
Clean look !!!! nice job,
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 05-06-2015, 09:45 AM   #4
vinmaker's Avatar
That is awesome. It looks so professional and clean.
The door end is attached to the PVC with small bolts? I seem to see the bolt heads in the pic. Is that true? How does the other end attach? Did you just put screws into the PVC?
Nice job.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-06-2015, 09:47 AM   #5
Looks a LOT better than mine! Good job! Youroo!!
Old 05-06-2015, 09:49 AM   #6
Nice...I'll make one for my power cable also!!!
FreddyCamper is offline   Reply With Quote
Old 05-06-2015, 09:50 AM   #7
Nice job.
Vin.
Looks like the Nuts are on the Outside. Flat Hd fasteners Cosunk on the inside! Youroo!!
Old 05-06-2015, 10:07 AM   #8
TURBS's Avatar
I seen this the other day in there recent mailed out spring book.
I was thinking it'd be great for awning matt and or awning shade!
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-06-2015, 10:13 AM   #9
TURBS's Avatar
You can find them on amazon as well.
TURBS
Old 05-06-2015, 10:25 AM   #10
BamaBob's Avatar
Annnnnnndddd ANOTHER option
This box is specifically designed for a Lippert WasteMaster Sewer system BUT it will work to store any sewer hose. They were selling them at Goshen last year for $50.00 It holds a 20' sewer hose, the big WasteMaster Nozzle, a sewer wrench, 3 adapters and still has room to spare (BTW, I like the WasteMaster better than a RhinoFlex It is a LOT more expensive than a Rhinoflex though )
ID:	76288   Click image for larger version
Name:	Wastemaster Sewer System.jpg
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
storage, modifications
