03-23-2011, 10:38 PM
Antenna Mod?
We've got a Sandpiper 35Loft. I set up my computer in the master bedroom, facing the washer/dryer area that we use as an office. Even though I'm a little higher there than elsewhere in the rig, I've noticed that wi-fi is moderate at best.
I know the walls and frame attenuate the signal to some extent, and I need a way to pipe the signal in. Well, I've got this retractable antenna for the TV, right? Can I piggyback a wi-fi antenna on that, and trace the wire back inside somehow to a repeater? I'm basically trying to avoid punching holes in the roof, and this idea struck me. Any thoughts? Anyone done this?
I can configure a wireless router, but I'm a lot less knowledgeable about the radio side of the system.
Bob Mueller | Fulltiming family of 9 since Feb 2011
More About Me
03-23-2011, 10:48 PM
silly question - where is your wi-fi signal coming from to begin with?
are you running a verizon wireless card that uses cell tower's or you trying to get the wi-fi signal from the parks?
Hope what I am asking makes sense
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
03-24-2011, 06:49 AM
I have a high gain WiFi antenna that I mounted on the top of my flagpole with zip ties. The antenna is connected to my USB Network adapter with a 25 foot extension cable. I route the cable through a gap at the bottom of a slide (it is very small diameter so no leaks or bugs).
I can pick up the WiFi signal when no one else in the park can at many campgrounds. At campgrounds that offer free "at site" WiFi I get very strong signal when others are marginal.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
03-24-2011, 01:30 PM
Problem is that most laptop/netbook/tablet now have built-in WiFi - so it's not possible to improve reception when you get a signal from a park Access Point. What I mean is, that you cannot add a gizmo or a more powerfull antenna to receive or send a stronger signal.
Options.
1. Move around to get a better reception
2. Use another method to connect like
a) a cell phone with data plan, tethered to your USB port and then you can try and aim better.
b) a data card to connect to cell network.
c) use a USB WiFi adapter (you will then have a 2nd network adapter, so you need to disable the 1st one) and use a long 8-10 ft cable to get a better position for the device. (Like herk7769)
3. Use a repeater/bridge - that is pretty complex to setup at each campground, some access point do not allow repeaters to be installed.
4. Get a site close to the access point...
5. Or... and finally forget about it - and enjoy your time camping with your loved ones.
(PS. I am certified wireless network pro)
Denis & Diane
* Happy Campers *
03-24-2011, 07:07 PM
AKA Indiana Jones
That is not correct. We have an all-aluminum trailer that acts as a giant Faraday cage, effectively blocking almost all but the strongest wifi signal. I got a Linksys WRE54G, and set it up at the door of the trailer. This usually doubles the wifi strength we get inside the trailer. Also, you can buy a USB wireless network card and USB extension cord, and place the network card up inside a roof vent where it can get a signal. I turn off the built-in wifi in my laptop and use the external card in this way when I don't feel like setting up the range extender, like when we are staying only one night while traveling.
Linksys Wireless-G Range Expander WRE54G Repeater - External
Terry
03-24-2011, 09:08 PM
Denis, we're not camping. We're fulltiming, and 'net access is important to us.
Sherdep, so far, we're just using the onboard wireless gear and park wi-fi. In the rig, I get about 24Mbps. Outside, I get 54.
Terry, thanks for that link. Lou, what hardware are you using?
More About Me
03-24-2011, 09:29 PM
Ahhh, that's different. Full timing... lucky you.
A separate USB stick WiFi adapter, strategically positioned, on a long cord should help then.
Good luck.
Denis & Diane
* Happy Campers *
04-13-2015, 09:48 PM
Please see my post about a Wi-Fi to WAN router made for motor homes, campers and long haul trucks.
04-14-2015, 05:59 AM
We do not use our bat wing antenna so I took it off and mounted our Wilson cell booster to the tubing that raises/lowers and turns. It boosts our cell signal for our wifi. We fulltime so when we get to a new park......just raise the arm like you would with the bat wing and are able to turn to get the best signal. I hooked it to the coax already up there which then hooks up to the inside antenna for the Wilson Booster .
04-14-2015, 07:24 AM
This is a terrific fix for getting access to free WiFi from a mile or so away.
1. 100’ Cat6 Ethernet Cable
2. RiteAV – Cat5e Network Ethernet Cable – Blue – 6 ft.
3. Ubiquiti BULLET-M2-HP Outdoor 802.11b/g M2HP
4. Celluteq 2.4GHz 15dBi Outdoor Omni-directional Antenna for WiFi and Wireless Applications
5. NETGEAR WG602 54 Mbps 802.11g Wireless Access Point
Set up and configuration are also easy.
The full blog article is here:
Learn How You Can Have FREE Wi-Fi In Your Rig
