Old 08-12-2013, 01:16 PM   #1
Jjs2000z's Avatar
Antenna wiring in bedroom
Can anyone help me out on how I can get antenna signal wiring hooked up in the bedroom on my 2014 stealth 2715? The only wire coming out is for cable hook up. I already installed the 12v outlet so I can hook up a tv. Now I just need to figure out how to get "the jack" tv signal to the bedroom.
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 08-12-2013, 01:35 PM   #2
dcheatwood's Avatar
You issue could be simple but need more info. Do you have a cable connection in the bedroom? Do you have a cable connection on the outside of your trailer? Do you have an antenna on the roof?, and is it connected to a cable going thru the roof?
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 08-12-2013, 01:38 PM   #3
Jjs2000z's Avatar
I have a cable connection in the bedroom. I have a cable outlet on the trailer. I do have an antenna.
I have 3 cable wires coming to the living room tv connection.
In the bedroom I only have 1 cable wire . In the bedroom it appears to only be the cable connection when hooked up to cable at campsites
2014 stealth 2714
Old 08-12-2013, 07:23 PM   #4
Paul & Sheri
pwb01's Avatar
I don't know if this is your condition. In my Rockwood I have 3 places where I can hook up a tv. In each case if I have a cable plugged into the outside jack I have to turn off the signal booster to get a signal from the cable. If I have the booster on, all three are receiving a signal from the antenna.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 08-12-2013, 07:29 PM   #5
Jjs2000z's Avatar
In the bedroom there is not a signal booster only one cable coming out if the ceiling seems to be for the cable only.
2014 stealth 2714
Old 08-12-2013, 07:42 PM   #6
VinceU's Avatar
Thinkin the bedroom and outside TV recepts. are duplicates the ant. from the roof to the LR. Sometimes the cables are not connected to the switch plate containing switch and booster. Otherwise bedroom is split at the booster and the outside TV is split from the BR in route.
Old 08-12-2013, 07:45 PM   #7
Paul & Sheri
pwb01's Avatar
In my unit there is one wire coming from the booster to a 4 way splitter. One wire from the splitter to the big tv, one to the basement (for outside tv) and one to the bedroom. One booster for all three. The booster with on/off switch in my unit is under the big tv in the living space.
By the way, I just hooked up my radio to the 4th leg of the splitter so my FM and NOAA signal is boosted and directional.
2006 Sunline T1950
2004 T@B T-16
Old 08-12-2013, 07:49 PM   #8
Jjs2000z's Avatar
The living room has 3 cables connected to the power antenna booster.
The one in the bedroom does not have antenna booster and only has one cable wire.
Where does the cable wire connect to from the bedroom?
2014 stealth 2714
Old 08-12-2013, 07:53 PM   #9
Paul & Sheri
pwb01's Avatar
One of the three wires from the living room booster goes to the bedroom. The one wire in the bedroom is cable with the booster off and antenna with booster on.
That's how it works in mine.
2006 Sunline T1950
2004 T@B T-16
Old 08-12-2013, 07:58 PM   #10
Jjs2000z's Avatar
So I must turn the booster on in the living room for the cable in the bedroom to work off of the antenna?
2014 stealth 2714
