Old 07-11-2011, 07:20 PM   #1
Antone have any experience with Steadyfast system
Hello all, new to forum not new to camping. I have been reading alot on issues and have gotten some Great ideas off the forum, Thank you all.
I have a lot of movement when set up. It ready doesn't matter if I'm on level ground or not. I have x-chocks. I am debating on getting a Steadyfast system. (I found this system on the forum). Does anyone use this system or one like it?
rplew716 is offline   Reply With Quote
Old 07-11-2011, 07:44 PM   #2
jimh's Avatar
i installed them on mine this past spring. they do make a big difference. i still get a little shake but not nearly what i did.
i was using a tripod on the king pin before the steadyfast still had a lot of shake.
first time out with steadyfast, very small amt of shake. second time out, landing gear was jacked way up and rear stabilizers were only down abt 6" and on a hill. had more shake in the back.
my opinion is that they work well. i would recommend them.
jimh is offline   Reply With Quote
Old 07-21-2011, 02:10 PM   #3
Love the Steadfast system. Not to mention, you can call Paul (owner) directly and he will answer any ? you might have.
c04678 is offline   Reply With Quote
Old 07-21-2011, 03:00 PM   #4
I hope it works great...just received mine today. Now, to undertake putting it on in this heat this weekend to get ready for our trip in 2 weeks!
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 07-22-2011, 05:40 PM   #5
jimh's Avatar
when u drill into the frame, just make sure there isn't anything behind it. i didn't have any problems but someone on another forum drilled into their fresh water tank.
Old 07-22-2011, 06:20 PM   #6
yvesm's Avatar
I installed the Steady Fast on my 2011 2902ss Rockwood and its great. I also replaced the "C" type jacks with ball scissor jacks and that also eliminated a lot of bounce.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 07-23-2011, 12:45 PM   #7
Thanks for the reminder...definitely have to take that into account!
Old 07-23-2011, 03:27 PM   #8
Jay Pat's Avatar
Just installed last week, easy!
Using now. Easy to use. Removed a lot of movement. (you are still on tires that give).
I am happy with the system.
Note: Less to install than other systems.!!!
Pat
Jay Pat is offline   Reply With Quote
