Old 02-22-2013, 08:38 AM   #91
Fire Instructor's Avatar
Originally Posted by garbonz View Post
Wire solar panels (I have them mounted on Yakima racks on my truck so I can get them in the sun while the camper is in the shade).
What size panels, and what size wire did you use to run from the panels back to the controller? I considered something similar, but didn't because the wire size needed to be heavier than a jumper cable, or else I would have suffered tremendous line-loss. Roof mounted my panels, instead.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 02-22-2013, 08:39 AM   #92
camper1999's Avatar
Mine is still covered but in 2 weeks:
-Wood panels install on Fridge
-Fridge fans
-Wheel bearing repack
-PD converter install
-Winegard sensor pro tv amp with signal meter
-install pump on extra 26 gallon water tank for dry camping
-access door on the duramax for quick change fuel filter
I have all the parts just waiting for the weather to break. This is how I get through the winter, thinking and planning for all the things to do with the camper.
2011 GMC 2500HD Diesel
Old 02-22-2013, 02:15 PM   #93
Further's Avatar
What meter did you use to monitor the 110 campground source?
Further is offline   Reply With Quote
Old 02-22-2013, 02:32 PM   #94
Denver, CO
garbonz's Avatar
I have two old BP panels that put out 8 amps at peak sun. So I use 10 gauge anchor marine wire with 2 25 ft sections so I can manage the voltage drop. It's amp dependent so battery cables are not necessary unless you have a lot of panels. The panels offset a typical days draw, usually, if I am careful. I have a 55ampcharger working off my Honda 2000 as backup.
2017 Fuse 23T
Old 03-11-2013, 09:34 AM   #95
camper1999's Avatar
-Fridge fans
Weather broke yesterday and I was able to uncover the trailer. I got in there and installed the wood panels on the fridge, installed an internal fan inside the fridge(the external ones go in next week), put in the Winegard sensor pro tv amp with signal meter, installed the pump on my extra 26 gallon water tank. I also used the 50 amp to 15 amp adapter I purchased at home depot which was great and saved me from dragging out the heavy 50 amp cord. Then I sat in there with a glass of wine, two more weeks to real camping....hitch itch!!!lol,,,,
Old 03-11-2013, 09:43 AM   #96
TURBS's Avatar
Hitch itch! I like that!
You know its an unspoken rule in here that all mods require pics!
Just sayin!
Turbs
Old 03-11-2013, 09:59 AM   #97
Phat Phrog
RVChick's Avatar
Yes please show pics! I would love to buy some fridge panels too! We currently have the black fridge covers, but Camping World has some cool fridge covers.....
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 03-11-2013, 10:31 AM   #98
camper1999's Avatar
Just sayin!
Turbs
Okay you twisted my arm I will have to go back in there today and take some pics...
Old 03-11-2013, 10:34 AM   #99
TURBS's Avatar
Better take another bottle as this could take awhile!
Turbs
Old 03-11-2013, 10:41 AM   #100
camper1999's Avatar
Turbs
You read my mind!
