Old 03-11-2013, 03:46 PM   #101
camper1999's Avatar
Originally Posted by camper1999 View Post
Weather broke yesterday and I was able to uncover the trailer. I got in there and installed the wood panels on the fridge, installed an internal fan inside the fridge(the external ones go in next week), put in the Winegard sensor pro tv amp with signal meter, installed the pump on my extra 26 gallon water tank. I also used the 50 amp to 15 amp adapter I purchased at home depot which was great and saved me from dragging out the heavy 50 amp cord. Then I sat in there with a glass of wine, two more weeks to real camping....hitch itch!!!lol,,,,
Here some pics...more to come
2011 GMC 2500HD Diesel
Old 03-11-2013, 06:32 PM   #102
AquaMan's Avatar
Over the weekend I finished my sewer line storage and built my pin box hitch for bike rack. Still have to build custom bike rack and grill swing arms.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-11-2013, 06:38 PM   #103
I like the color match detail,nice touch! Youroo!!
Old 03-11-2013, 07:16 PM   #104
GlacierGus's Avatar
ttrost65-i'll be real interested to see your bike rack solution. please post some pics of that as well. nice sewer line storage!
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 03-11-2013, 08:10 PM   #105
AquaMan's Avatar
Will do. I used golfmediks pin box mount design, but I've designed my own bike rack that will hold 4 bikes in the forward space of 2
Old 03-12-2013, 10:30 AM   #106
golfmedik's Avatar
Please post pics as my design may need some altering!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-12-2013, 10:49 AM   #107
phat phrog stunt crew
camper1999 .... thats a lot of projects accomplished in one day. i feel like such a slacker.
dwaynerz is offline   Reply With Quote
Old 03-12-2013, 11:29 AM   #108
5050 LED lights installed under camper (2516g) along frame rail tied into a rf audio controller. It's plugged into our stereo so it flashes as the music plays.......very high-tech.
Trevor43 is offline   Reply With Quote
Old 03-12-2013, 12:03 PM   #109
Denver, CO
garbonz's Avatar
Last weekend did the install on my Winfield Stabilizers and recieved my rotochoks, which seem to be REALLY Great.
I like the way you can tighten the Winfields after you pin them. The combination of the Winfields and the RotoChoks seem to work as well as the Steadyfast system I had in my last unit and MUCH easier to install.
I put LED's from Superbright throughout the camper. They worked pretty good, but the plug in part of the LED is a little bit thinner than the glass bulb, so I have had to spread the contact in the socket a little bit on some of them. For anyone interested, they are the WLED-WWHP15-TAC in Warm White and they are the same (or very close) to the original bulbs and a teensy bit dimmer.
Rerouted the water line from the pump to stop the annoying vibration coming from the pump. I may put a section of flexible line in there to isolate it further.
Sanitized the tank and plumbing with 100PPM chlorine.
Cleaned and converted my Superglide hitch from grease to Slip Plate graphite based lubricant (very messy but rewarding).
Replaced the battery door with a bigger one and put a couple 6 volt deep cycles in there with my 55 amp super, temperature compensated charger for VERY quick recharging when I am dry camping.
Installed the Intellijack system on my landing jacks.
Many other Misc items etc.
On the List...
Vortex II fan in the bedroom
A couple of 12 plugs in the living room
Foam in all the voids and holes with black foam.
Hardwired surge protector (Progressive)
Hardwired Inverter with auto switchover (maybe)
2017 Fuse 23T
Old 03-12-2013, 12:13 PM   #110
camper1999, where did you got your fridge panels and were they hard to install? I've looked for some like that and all I can find is the flat ones. Already have that.
choice spot is offline   Reply With Quote
