Old 03-24-2013, 02:20 PM   #131
AquaMan's Avatar
Originally Posted by PHS79 View Post
No mods done yet, but I have 4 boxes with 7 different things inside of them that need to be installed on the camper if this spring. That is if it ever warms up enough to get the camper out of storage!
ttrost, what grill is that?
It's a charbroil 3 burner, without the cart and one of the shelves. It's the right size and weight for what I wanted. $149 at Home Depot.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-24-2013, 04:03 PM   #132
AquaMan's Avatar
Originally Posted by f1100turbo View Post
Yep they did.
Using an app and phone?
I am! Things are also a little "phuzzy"!
Old 03-24-2013, 04:38 PM   #133
golfmedik's Avatar
Originally Posted by ttrost65 View Post
Here are some pics of bike rack without bikes.
Very nice job! I am going to look for a rack to disassemble and use in my next one. Very neat design. Bet you get lots of looks driving and pulling into the campground!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-24-2013, 05:22 PM   #134
Camper Less Camping
Cajun Po-Boy's Avatar
Rear jack mod using truck bed cargo bar to eliminate side to side movement (Sabre model in pic)...bolt on application & everything stores in rear bumper tube if you don't permanently install to frame.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-24-2013, 05:25 PM   #135
TURBS's Avatar
Little ?
Old 03-25-2013, 06:02 PM   #136
Leecountry's Avatar
I see how you attached to the foot but what and how di you connect the other side? Also have you tested stability yet with this mod? BTW looks nice
Leecountry is offline   Reply With Quote
Old 03-25-2013, 06:35 PM   #137
Camper Less Camping
Rubber foot pad is wedge into top corner of frame, as you apply handle tension, it snugs very tightly & holds firm.
Yes, I did a dry fit to test application & retested after final install...camper is solid as a rock as you push the back in a side to side motion and as you walk in the rear of the camper, absolutely no movement.
Old 03-25-2013, 09:34 PM   #138
Stank Bait's Avatar
Ragin Cajun,
Got any close up pics of the attachment points of the truck bed cargo bar? This is a great idea. Assume you drilled the lower end and added pin/bolt? Do you have one at both ends? The pic enlarges, I see it now. Thanks.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 03-26-2013, 08:23 AM   #139
Camper Less Camping
Originally Posted by Stank Bait View Post
Ragin Cajun,
I removed the footpad on one end of cargo bar & drilled the holes to the same size of hex bolt for a firm fit.
The other foot pad that wedges against the frame, I removed the bolt and use a coupler pin so I can quickly detach the footpad from the cargo bar to stow away in the rear bumper.
Old 03-26-2013, 09:50 AM   #140
Stank Bait's Avatar
Will get some measurements of my set up for purchasing the bars. I assume that is a Northern Tool or HF bar. Have a trailer so I will need one at the front too. Was looking for a simple way to stop the shake. Thanks.
