Old 03-29-2013, 10:00 AM   #141
AquaMan's Avatar
Do you have any detail pics of the grill swing arm? I've taken some pics of a few commercial ones, but if love to see what you did.
Finally got around to getting some individual pics. Mostly used 1/8" 2x2 tubing, 1/4" plate, and 1/8" 1x1. Used a cut up lube plate for bearing surface, will replace with actual full diameter nylon once home. Also intend to strengthen the bumper mount.
ID:	26638   Click image for larger version
ID:	26639   Click image for larger version
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-29-2013, 10:15 AM   #142
TURBS's Avatar
Looks good Timmy!
Old 03-29-2013, 10:27 AM   #143
Nice job!
Old 03-29-2013, 11:39 AM   #144
AquaMan's Avatar
Wish I had more time to engineer and fit to camper instead of engineering, building and mounting in 3 different locations. I'm gonna make some modifications when I get back.
Old 03-29-2013, 01:35 PM   #145
RubenZ's Avatar
nice view
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 03-29-2013, 01:40 PM   #146
AquaMan's Avatar
It is, except those are my daughters on front of me. Guess I should have taken a different view. Turbs, close your eyes!
Old 03-29-2013, 01:41 PM   #147
TURBS's Avatar
I didn't see nuthin. ......
Old 03-29-2013, 02:12 PM   #148
AquaMan's Avatar
Sure you didn't!
Old 03-30-2013, 04:30 PM   #149
camper1999's Avatar
I bought a 26 gallon water tank, added a pump, the pump plugs into my trailer connection on the back of my truck. It worked great on our trip to a state park with no water, made refilling the fresh water tank a breeze
2011 GMC 2500HD Diesel
Old 03-30-2013, 10:29 PM   #150
Drinkin beer on the beach
Rod Johnson's Avatar
Dont know about mods...
I was dealing with this...
When I found this
Looks like that tire may have taken a hard hit and when the u-bolt contacted the frame, it cut clear through the ground wire. I have things rerouted so that cant happen again. It happened a while ago, I remember noticing the tire had a funny shape to it months and months ago, but didn't realize it was starting to seperate. Trailer is only 16 months old, with maybe 5k miles on it.
Could have been way worse, I suppose.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
