Old 02-22-2012, 04:18 PM   #41
I added a soap/shampoo holder in the shower. I had to modify the flag holder and mount it to the ladder since the crappy suctions cups won't hold it anymore. I also built and mounted a sewer hose (pictured) out of a pvc fence post.
Name:	Sewer hose holder.jpg
Len & Cheri is offline   Reply With Quote
Old 02-22-2012, 05:46 PM   #42
wfmdfm's Avatar
I upgraded my sound system. Took my time and picked away at it since Nov and finished up this weekend.
Modification to the sound system
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 02-23-2012, 07:34 PM   #43
I am thinking about turning the 1 step up inside to 2 steps so it will not be so steep. I know it would have to be removable so I could access the furnace if I had to work on it.
Has anyone done this before?
murrayflagstaff is offline   Reply With Quote
Old 02-23-2012, 09:35 PM   #44
Mpjduff's Avatar
What soap shampoo did you use and sewer hose does it effect your clearance.
Mpjduff is offline   Reply With Quote
Old 02-24-2012, 11:19 AM   #45
tonyz's Avatar
Just got done putting an outlet and charger in the storage compartment and a cordless drill will now be charged at all times.
Tony Z
tonyz is offline   Reply With Quote
Old 02-24-2012, 01:02 PM   #46
acadianbob's Avatar
Too darn cold here in MN to even consider going to the barn to work on the trailer!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-24-2012, 01:18 PM   #47
I bought the soap/shampoo holder from Target. It's just a silver metal basket type. Still unsure if the double sided tape I used will hold.
No clearance issues with the holder. If you look at the pic you can see the rear stabilizers hang lower than the holder.
Old 02-26-2012, 12:31 PM   #48
backin15's Avatar
Originally Posted by 3 Happy Campers View Post
Here my mod report so far.
Regarding the RV Door Buddy storm door conversion, Iíd give 3 stars out of 5. I liked that they call you back & double check your measurements. They prefer if you use a metal yard stick. They wrap all four edges of each panel with vinyl, nice touch. However once I received the panels there was a little slop in how they fit. I went to Lowes & got some 7/16Ē thick self-stick weather stripping & that helped. If you have the right circular saw blade, a jigsaw to cut the radiuses & something to wrap the edges with I think you could do a more custom fit job yourself for half the price.
The wireless RV Door Lock on the other hand is freakin sweet! I got the extra keypad too. Took longer to unwrap everything than it took to install. I still have to play with it a little & tweak the strike plate but other than that there were no issues. 5 stars out of 5.
50 Amp surge guard, once I got in place it only took 10 mins. Had to use a pair of bolt cutters to cut the main feed cable.
Didnít have quite enough slack to mount it completely vertical. Not going to lose any sleep over it. Hope I never have to do a follow-up report on this mod.
Inspection next week & then Iíll install the central vac & IntelliJack Level Ease System & Combi-cam locks.
I have a two door camper and hate having seperate keys, do you know if one remote or keypad can unlock both doors?
backin15 is offline   Reply With Quote
Old 02-26-2012, 03:03 PM   #49
3 Happy Campers's Avatar
Technically yes you could use one key pad or key fob on multiple doors. There are instructions included to train the door lock to recognize the key pad / fob. The only thing it would lock/unlock both doors at the same time. It would not differentiate between the doors. I guess you could have separate key pads for each door & a one key fob to work both doors.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 03-11-2012, 12:06 PM   #50
HemiCab's Avatar
Ok here at some pictures of my doors after installing the Velcro and Lexan. Not perfect but it will work to allow us to use heat or AC and keep the solid doors open for the light and views. HC
ID:	10825   Click image for larger version
ID:	10826   Click image for larger version
ID:	10827   Click image for larger version
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
