Old 04-08-2012, 07:57 AM   #61
Herk7769's Avatar
Sid, I am blown away.
How cool is that!
You of course are going to post more than just a "finished" photo right?
I, for one, would like to know the grizzly details like who ya bought em from; what they cost; and if you had any problems installing them.
HAM CALLSIGN - KC3FFW
Old 04-08-2012, 09:25 AM   #62
I have also added 2 to each door. Bought 18 on ebay a couple of yrs ago for $20. Main thing is the door anchors must be put on a larger plate (Alum) and riveted to the door as they are only vinyl & foam and the frame anchor should also be reinforced to the wall to eliminate flexing of the frame.
Old 04-08-2012, 09:31 AM   #63
Herk7769's Avatar
I don't care who posts it; I want to know!
Old 04-08-2012, 09:40 AM   #64
jonnys_walkers's Avatar
Equa-Flex
Originally Posted by Fire Instructor View Post
Any details on the shackle-kit that you used, Jonnys?
Equa Flex Suspension Enhancement
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 04-08-2012, 10:53 AM   #65
Herk7769's Avatar
OK, anyone wanting to catch me in a mistake, point them to this thread too.
Disregard my posts regarding moving this one as I found FireInstructor's post further down.
VERY embarrassed.
Old 04-08-2012, 11:16 AM   #66
Here are the storage door struts I added.
Forest River Forums - dunnnc's Album: Gas Struts on storage doors
Old 04-14-2012, 07:40 PM   #67
MIKE44460's Avatar
Well this project has been going on for a couple of weeks now. I want my RV to be seen. It just blows my mind that all the manufactures use the same light, tail & turn, and clearance on all RV’s. When I have to get on the brakes I want the guy/gal behind me to know I’m on the binders, so.
I added red LED’s to the existing rear lights for stop and turn. I also put a nice polished piece of stainless behind the bulbs. In addition I also added two round four inch LED’s to each side below the bumper. So now I have three stop, turn, and tail on each side. Then the wheels really started to turn.
I ciphered out how and tested it and it does work, when the running lights are on, and the left or right turn signal is on, the lower clearance lights on that side will flash opposite of the turn signal. Now if the brake lights are on, brakes applied, the clearance lights will not flash until the brakes are released.
On my 831RKBSS it was easy to find all the connections inside for the lower clearance lights. I’m running a fused hot wire to each of the six lights. The wires will run under the floor between the bottom cover and the relays and fuses will be located under the lower drawer in the kitchen. This will make access easy with the slide in or out.
So if you see some guy flashing, it is me, er, ah us. And Lu, when she found out I had over $250 in this little adventure; I just received another “Oh Brother”.
Mike & Lu Anne
& our Jack Russell 'Genny'
2011 Flagstaff 831FKBSS
2011 Chevy CC Duramax Z/71
OH plate GM DMAX
Hensley Arrow
MIKE44460 is offline   Reply With Quote
Old 04-14-2012, 09:40 PM   #68
Drinkin beer on the beach
Rod Johnson's Avatar
Originally Posted by jonnys_walkers View Post
Upgraded 12 volt power supply. Solar System is in transit.
Jonny, which solar kit did you order?
I got paid this weekend, sat down paid the mortgage and all the other bills and had just enough left over to order two solar panels. Everbright was supposed to have free shipping, but the online cart couldn't calculate it.
I guess I'll call on Monday and see if I really do have enough money to order the panels or if I need to keep shopping.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 04-14-2012, 11:02 PM   #69
Due to wife's complaining, made one step into two (cut-out on bottom is for the carpet when the slide is in). Two screws hold it in place.
Since finally checked into how to add pictures (thanks herk) added one of clips installed to hold table in place when traveling Worked o. k. so far.
Third picture is counter extension (may need to refinish top, although not as bad as it looks in the picture). Tried to use the t. v. shelf from the bed room or the grill shelf, but they were too narrow for the brackets to clear the drawers. Wayne
Name:	2012 03 006 5th wheel 5 (640x480).jpg
ID:	12184   Click image for larger version
Name:	2012 03 007 5th wheel 6 (640x480).jpg
ID:	12185   Click image for larger version
Name:	2012 03 005 5th wheel 4 (640x480).jpg
wayne anthony is offline   Reply With Quote
Old 04-14-2012, 11:58 PM   #70
Wayne Anthony, nice job on all the projects.
Rod Johnson
I got the 190W MPPT Package.
It was complete with panel, controller and remote read out for $699.00
Here is the website:
Solar Panel Systems Vancouver Burnaby BC
