03-22-2013, 12:45 PM
#121
I had a blowout and the shredding tire did its own mod to the side of the camper. Does that count?
Matt & Kathie
2022 Cedar Creek
03-22-2013, 07:46 PM
#122
Umm..only if you fix it yourself Dang, hate to hear that!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
03-22-2013, 08:14 PM
#123
Been there, done that 4 yrs ago. $1800 damage + 4 Goodyear Marathon LRD tires to replace the factory junk, repaired it myself, not fun.
03-24-2013, 01:05 PM
#124
Here are some pics of bike rack without bikes and of grill in use position. Need to get quick disconnect fittings for grill yet.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
03-24-2013, 01:07 PM
#125
No happy family photos ?
03-24-2013, 01:11 PM
#126
Always Learning
Finally got the bike rack, pin box mount, and grill swing arm done. Ready to roll in the morning.
Do you have any detail pics of the grill swing arm? I've taken some pics of a few commercial ones, but if love to see what you did.
03-24-2013, 02:00 PM
#127
No mods done yet, but I have 4 boxes with 7 different things inside of them that need to be installed on the camper if this spring. That is if it ever warms up enough to get the camper out of storage!
ttrost, what grill is that?
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
03-24-2013, 02:17 PM
#128
Here are some pics of bike rack without bikes.
03-24-2013, 02:18 PM
#129
Didn't think first ones loaded
03-24-2013, 02:19 PM
#130
Yep they did.
Using an app and phone?
03-24-2013, 02:20 PM
#131
It's a charbroil 3 burner, without the cart and one of the shelves. It's the right size and weight for what I wanted. $149 at Home Depot.
03-24-2013, 04:03 PM
#132
Originally Posted by f1100turbo
Yep they did.
I am! Things are also a little "phuzzy"!
03-24-2013, 04:38 PM
#133
Very nice job! I am going to look for a rack to disassemble and use in my next one. Very neat design. Bet you get lots of looks driving and pulling into the campground!
03-24-2013, 05:22 PM
#134
Camper Less Camping
Rear jack mod using truck bed cargo bar to eliminate side to side movement (Sabre model in pic)...bolt on application & everything stores in rear bumper tube if you don't permanently install to frame.
2013 Sabre 32RCTS-6 (sold)
03-24-2013, 05:25 PM
#135
Little ?
03-25-2013, 06:02 PM
#136
I see how you attached to the foot but what and how di you connect the other side? Also have you tested stability yet with this mod? BTW looks nice
03-25-2013, 06:35 PM
#137
Camper Less Camping
Rubber foot pad is wedge into top corner of frame, as you apply handle tension, it snugs very tightly & holds firm.
Yes, I did a dry fit to test application & retested after final install...camper is solid as a rock as you push the back in a side to side motion and as you walk in the rear of the camper, absolutely no movement.
03-25-2013, 09:34 PM
#138
Ragin Cajun,
Got any close up pics of the attachment points of the truck bed cargo bar? This is a great idea. Assume you drilled the lower end and added pin/bolt? Do you have one at both ends? The pic enlarges, I see it now. Thanks.
2013 Flagstaff 831FKBSS
03-26-2013, 08:23 AM
#139
Camper Less Camping
Originally Posted by Stank Bait
Ragin Cajun,
I removed the footpad on one end of cargo bar & drilled the holes to the same size of hex bolt for a firm fit.
The other foot pad that wedges against the frame, I removed the bolt and use a coupler pin so I can quickly detach the footpad from the cargo bar to stow away in the rear bumper.
03-26-2013, 09:50 AM
#140
Will get some measurements of my set up for purchasing the bars. I assume that is a Northern Tool or HF bar. Have a trailer so I will need one at the front too. Was looking for a simple way to stop the shake. Thanks.
