Old 06-22-2016, 12:19 PM   #11
We have a rooftop heat pump. The roof is a huge sounding board. The compressor's vibrations are amplified by the roof. No way around it other than a basement unit. In 50 years of RVing, we've learned to appreciate the AC drowning oht campsite noises.
Blest with a Coachmen Prism 24G
I Simpson is offline   Reply With Quote
Old 06-22-2016, 12:39 PM   #12
Also if you take the cover off of the unit on roof, look at the tubing coming out of the compressor and make sure its not touching/rubbing against any of the sheet metal. Mine was just touching the sheet metal and made a awful noise. I turned the unit off and let it cool down and bent the tubing just a bit 1/8" with my hands and got it off of the sheet metal, made all the difference in the world. I still have the air noise but the vibration noise is gone.
pinkstonj is offline   Reply With Quote
Old 06-22-2016, 12:53 PM   #13
Originally Posted by Harveyfamily View Post
We have a Wildwood 195BH with an overhead AC unit. It is LOUD! Does anyone know if there's a way to quiet down an AC unit? It's a Dometic.
Remove it and install a portable AC... much quieter, way more efficient and can be ran on a 2K generator easily. Only drawback is you must have an accessible window to vent it through.
2007 Dodge RAM 2500 5.9L
2010 Wildcat 30-LOFT
bradleyr001 is offline   Reply With Quote
Old 06-22-2016, 05:31 PM   #14
About 6 months ago someone posted about fabricating a shroud that incorporated some sound deadening material. It got posted also to irv2.com and rv.net. Do a search.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 06-22-2016, 06:00 PM   #15
Left Coast
If one was so inclined, could use a shore power compartment and run a portable exhaust hose into it......then when not using, close the flap.......or, JR Products make compartment boxes of various sizes, with doors......bore the hole size, mount the box using butyl tape.
Old 06-22-2016, 06:47 PM   #16
Originally Posted by bikendan View Post
THIS^^^
Blast From the Center a/c (non-ducted) will always be louder the ducted a/c.
Mine is ducted, but still loud. I expect it will always be that way. As long as it is cold I'm happy! Lol
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 06-22-2016, 06:52 PM   #17
BandJCarm's Avatar
If the folks next to me at this campground don't move, I'd like to know how to make mine LOUDER!!! LOL
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-22-2016, 07:02 PM   #18
Wobbles's Avatar
Air can "Boat Horn". Either one of you may have to leave.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 06-22-2016, 07:14 PM   #19
BandJCarm's Avatar
I can't leave.
I'm in a pull through site with two 100' pine trees in front of me. Can't make 90 degree left turn when leaving. Camper ain't gonna leave fronterds (Southern for frontwards).
I have to live here forever.
FROG AR-0019-242
Old 06-22-2016, 07:39 PM   #20
northstar1960's Avatar
They are real quite when turned off .
I have a 15000btu dometic it is louder when using the cold air dump but when that's closed and the air is going through the vents i do not find it any louder then one may expect , very normal and quieter then my home window air unit
northstar1960 is offline   Reply With Quote
