Old 06-21-2016, 07:12 PM   #1
Any way to quiet overhead AC?
We have a Wildwood 195BH with an overhead AC unit. It is LOUD! Does anyone know if there's a way to quiet down an AC unit? It's a Dometic.
Harveyfamily is offline   Reply With Quote
Old 06-21-2016, 08:06 PM   #2
grumpy0374's Avatar
Short answer...NO!
Long answer....NO!
Nature of the beast. Their all loud, whether in a small trailer or a 32' class c, or a 40' 5th wheel.
Grumpy
Steve & Cheryl + Charlie & Zoey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-21-2016, 08:10 PM   #3
Yes, but you won't like the answer
The Atwood 13.5K and 15K BTU A/C's are much quieter than the Dometic. We removed our Dometic 13.5K unit on our Forester MBS - even though it worked fine - and replaced it with a 15K Atwood heat pump. We couldn't hold a conversation at the dinette directly below the ceiling diffuser with the Dometic. Now with the Atwood (even on high) - we can eat and talk without yelling.
The Atwood also draws much less current and the low/med/high speeds actually are different, unlike the low/high of the Dometic.
KatanaPilot is offline   Reply With Quote
Old 06-21-2016, 08:30 PM   #4
My Coleman Mach was very loud , a finally the electric fan motor quit , I replaced it with a new one night an day difference , You can actually carry on a conversation.
Soga65 is offline   Reply With Quote
Old 06-21-2016, 08:37 PM   #5
waiter21's Avatar
LOUD... Is amazing how loud it is inside, yet when you go outside, its actually very quite...
I've looked at mine, I believe there is two source of noise:
1) The AC unit seems to vibrate the entire roof, so the roof amplifies the sound.
2) Wind noise, It moves air at very high speed, which translates to noise.
There isn't any way that I can see to quit it down...
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-22-2016, 05:03 AM   #6
grumpy0374's Avatar
Remember, the OP has a 19 foot tt. Nothing installed on that rig, no matter what the brand, is going to be "quiet". Dosen't even have any type of doors to seperate the bedroom section from rest of tt. AC is going to be loud!
Grumpy
Old 06-22-2016, 05:26 AM   #7
heavynlori's Avatar
Originally Posted by grumpy0374 View Post
Short answer...NO!
Long answer....NO!
Grumpy
Our Crusader has the Quiet version ducted air that does NOT have that grate in the middle of your ceiling with the sliding portion to dump cold air if needed
It is more like a regular central air system - it has two cold air return vents in the ceiling and it is extremely
quiet compared to any other we have had in previous fivers..you can actually watch TV at normal volume levels 😊
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 06-22-2016, 06:03 AM   #8
grumpy0374's Avatar
Again, the OP has a 19 foot tt, with a non ducted ac unit. It is going to be much louder than a ducted 5th wheel. In a small tt that is basically an open box, even a "quiet" ac unit will still be loud. Big difference between his rig, and a larger 5th wheel, or MH with a ducted ac unit.
Really no way to "quiet" it down. Even spending 6-7-8 hundred dollars to have a "quiet" ac unit installed would not cut down noise that much.
Grumpy
Old 06-22-2016, 11:38 AM   #9
bikendan's Avatar
Grumpy
THIS^^^
Blast From the Center a/c (non-ducted) will always be louder the ducted a/c.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-22-2016, 11:46 AM   #10
As for the vibration, I would suggest removing the roof cover and inspecting the fan blades for mud dauber nests. Been there, done that.
