Old 02-21-2013, 05:11 PM   #11
grege's Avatar
Originally Posted by gmccarth1150 View Post
So no one has ever used this? It would take me a bit of negotiations (read begging) with the wife but it does look like I could use the for my tight spots next to the garage.
I live in a new neighbor hood that is an old style. We have alleys and our garage is off that so I can't store mine at home. Had a popup since 2001 and this is the first year I had to pay for storage so I have plenty of room to get it in my spot.
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 02-21-2013, 05:25 PM   #12
B47
Originally Posted by grege View Post
Cool idea and might work for you.
Unless I missed something in the video, there is no lateral (side to side) movement, just fore and aft. So you will still have to be right on as far as having the TT hitch in line with TV hitch.
Did I miss something?
Old 02-21-2013, 08:01 PM   #13
10x
It does have a steering handle, the guy is holding it with his left hand as he cranks it
10x is offline   Reply With Quote
Old 02-21-2013, 08:17 PM   #14
TURBS's Avatar
ever try to turn a tandem axle trailer by hand ?
even tho it has a "steering lever I don't see cramming it into a turn and this thing going where you want .
maybe im wrong.
Old 02-21-2013, 08:20 PM   #15
FloridaPhil's Avatar
Thanks for sharing, cool idea
FloridaPhil is offline   Reply With Quote
Old 02-21-2013, 10:04 PM   #16
B47
OK - I guess I did miss it.
Knowing that - if I had a TT I might look into getting one of them.
Old 02-22-2013, 05:24 PM   #17
Explorer
use something like it
I use one similar for our boat; we also have a couple small tight/strategic maneuvers on a slight up hill to get it in the back yard. I can now move my trailer very simply by myself, mine is very slow and thatís good.
I know someone made mention of the tandem axle and that does make it tougher with sharp turns. We went from a single axle to a tandem axle and if the last movement on the trailer is a tight turn the trailer will try to straighten its self to relieve tension between axles.
We have had ours for 12 yrs with the only issue being the bolt on handle would come loose and break bolts(4 in 10yrs and always loosened). I finally welded it with a couple gussets added and now its stout , no more bolts. I use an offset-bolt-on Ėframe bracket because of a beautification strip of river rock down the middle of our drive way. Moving a trailer from the tongue with a ball would be more maneuverable. I bought ours from a company outside of LA(Ca) found them on the internet but have seen them in RV magazines. When I called he helped me pick the right model(3 pneumatic wheels/ Ĺ hp motor) with the correct gearing(something like ľ ml/hr or slower) based on what I had and what I was trying to do with it(moving 60 ft total). I think mine is robust and functional but not fancy and as I recall it was $650, 12 years ago.
So, they work, go slow be safe
John
ID:	24648   Click image for larger version
YoungKopernik is offline   Reply With Quote
Old 02-22-2013, 05:52 PM   #18
caper's Avatar
The leaver is the breaking system. I would not want to be in front of the trailer if it was on a hill and the breaks did not work. If you watch the video when he released the handle going down hill the boat really wanted to go.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-22-2013, 09:47 PM   #19
Explorer
its been a while since i bought but I could have gotten a break. As it is I make sure I have a 2x4 handy for the dolly and while that seems to be enough i still place chaucks on fenders ready to go. It seems to work for me but each should do for there own situation.
Old 02-24-2013, 11:46 PM   #20
Campingnut's Avatar
I see Cabelas is also selling them under the name triglobal jack, or should I say looks like the same thing.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
