Old 02-12-2011, 12:17 PM   #21
Send a message via Skype™ to scubieman
Acadianbob it is really nothing with your wiring as it is for your breakers.
For example if your wiring in the RV is hooked to a 30 amp breaker. The chances are that both the wire and outlets can handle lets just say 35 to 40 amp.
It's very similar to a idiot light in a vehicle. You can't really over load the circuit cause the breakers won't let you.. In this case the breaker pops.. You reset and lessen the load.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 02-12-2011, 01:38 PM   #22
MotocrossCamper's Avatar
We use this heater, it works great cause it has a thermostat, it's pretty heavy duty, it has a fan, and it's best feature is that it has a switch for 750/1500 watts. We can put it on 750 during the day when we need more power in the RV and at night we can switch it to 1500 when it's colder and we aren't using near as many Amps. Even on 750 watts it makes a big difference.
MotocrossCamper is offline   Reply With Quote
Old 02-12-2011, 08:42 PM   #23
acadianbob's Avatar
Thanks! b
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
