Old 08-25-2014, 03:48 PM   #1
mikkeeh's Avatar
Are awnings over the slide outs worth the $
I see many RV's with awnings over the slide outs? What purpose does this serve? I realize it helps keep the weather off of the roof of the slide.....but aren't they designed to handle weather. Trying to justify if they would be worth the expense to install?????
mikkeeh is offline   Reply With Quote
Old 08-25-2014, 03:52 PM   #2
Fulltime family RVer
People fall into a few camps regarding awning toppers:
1) Never had and don't ever see a need
2) Have and will always have again
3) Have and won't have again (very rare)
The advantages are that the awning toppers keep pine needles, leaves, etc. off of the slide. They keep the camper cooler by keeping the sun from beating directly on the slide. They keep the rain off of the top of the slide - water runs off either immediately or to the sides when you bring the camper in. You get marginal protection when the slide is partially deployed. For bedroom slides, they keep the camper a little quieter in the rain when the slide is directly above your head.
The cons are that they're something else to go wrong; people have no issue climbing up to clear their slides before bringing them in; people just plain don't see the point.
More info here:
http://www.learntorv.com/2014/01/sli...efinitely.html
Personally, I'm strongly in camp #2 - have them now and will always have them in the future.
Old 08-25-2014, 03:54 PM   #3
Keeping the weather off is one factor and the toppers help to keep water out in case of a storm. But they also keep leaves, pine cones and other things from the top of your slide which could impede the closing of the slide.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Autostop
DSurette is offline   Reply With Quote
Old 08-25-2014, 03:56 PM   #4
Witch Doctor's Avatar
They are called toppers, It keeps the dirt out when you pull the slide in and you don't have to sweep them off when you close the slide, also helps with the sun and rain, wouldn't own a trailer without them anymore.........
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-25-2014, 04:18 PM   #5
golfmedik's Avatar
I fall into the category of having them and won't be without them again. I love then.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 08-25-2014, 04:35 PM   #6
vinmaker's Avatar
Yep. Just to keep the stuff out of the camper when you close the slide out. That is the whole purpose.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-25-2014, 05:03 PM   #7
offroad's Avatar
I'd probably fall into category 1 but I can see why others like them.
The unit we ordered has three slides and toppers would have cost $1,000
I like to check out the roof on a regular basis so taking a broom to the slide outs isn't a big deal for me.
If you keep the rig long enough your eventually going to be replacing the material.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 08-25-2014, 05:24 PM   #8
My new Rockwood 2703ws will have them. My older 2005 Sun valley did not. We cut a piece of carpet the depth of the one slide and attached a rope to both ends. Throw it over the slide and pull it back and forth to clean the top. Was told that the larger slides can absorb a lot of heat. Very little insulation at the top.
Ford F-150 5.0 3.55 super cab
New 2703ws came off line July 31st. Still waiting in Florida.
Rockwoodjoe is offline   Reply With Quote
Old 08-25-2014, 05:28 PM   #9
heavynlori's Avatar
Slide toppers were a must have when we bought our Crusader - had two fivers before without...never again!! Lot less debris and quieter too 😉
heavynlori is offline   Reply With Quote
Old 08-25-2014, 05:37 PM   #10
Infractee
More info here:
Learn To RV: Slide Toppers (aka Awnings) - definitely!
I am in camp #2 as well, could not understand somebody in camp #3 until somebody on here mentioned that he camps on the beach semi-full time and the constant wind off the sea made them flap 24-7 and it drove him nuts. We have camped in some windy spring times and the flapping can be a bit annoying.
RhoZeta is offline   Reply With Quote
awning, slide, slide out
