Old 06-05-2008, 10:47 AM   #1
attaching things to walls
I am new to travel trailers, having just bought a 2005 Wildwood 311BHBS.
I'm worried about attaching things to the walls. In particular, a towel bar
in the bathroom (exterior wall--it seems very thin) and an articulated LCD
arm (interior wall).
Can I go ahead and attach these like I would at my house with its drywall
on wooden studs? I would think not, but I'm not sure how to proceed.
Please advise.
bassclar is offline   Reply With Quote
Old 06-05-2008, 11:33 AM   #2
wildwood's Avatar
I have 29BhBS wildwood.
the studs are on 15-16 centerline.wood screws work best if you find a stud, if a stud finder doesnt work drill a very small dia hole, but you can normally find them, sometimes by pushing in on the wall. the wall coverings on over very thin wood/ board on to wood studs
I just hung towel racks in our bathroom using the small plastic inserts with screw, work easy.
in the cabinets , i just drill a pilot hole in the wood cabinet and screwed in the small metal hooks wth the screw that is a part of the hook. ll the stick on stuff i had tried has fallen off the wall.
enjoy your camper
2008 Wildwood LE 29BHBS
wildwood is offline   Reply With Quote
Old 06-05-2008, 11:44 AM   #3
KyDan's Avatar
I just use sharp sheet metal screws for towel bars and such.
I don't drill a pilot hole but just let the screw do the work.
Do be careful and don't over tighten and strip the screw!!
For my LCD TV mount I pressed on the wall and found a "stud".
In my trailer the interior walls have wood studs that are no more
than an inch thick. I drilled small pilot holes to be sure I hit
the stud and didn't split it with the larger 1" wood screws.
It seems to be pretty solid.
I also placed screw in cup hooks on either side of the TV so I can
put a bungee cord across the front when we are on the road.
I wouldn't want the TV arm to swing out while we were driving.
A big bump with the TV way out there could pull out the screws!
Good luck!
KyDan
Old 06-05-2008, 12:22 PM   #4
So even the exterior wall in the bathroom has these studs? I almost convinced myself that it was the plastic woodgrain stuff directly on the metal wall. I didn't want to put my towel-rack screws through to the outside.
Old 06-05-2008, 02:43 PM   #5
KyDan's Avatar
An exterior wall likely has aluminum studs with the fiberglass glued
to the outside and the 1/8" paneling glued to the inside.
Do be careful not to run a screw thru the outside skin!!
You can probably get an idea how thick they are by looking inside
one of your outside storage areas.
Good luck!
Old 06-05-2008, 07:57 PM   #6
Cyber Phrenologist
Radio's Avatar
I'm trying to find some of those magnetic hooks that were so popular years ago. They would be perfect for hanging a few pot holders from the range hood.
Every place I have wandered through doesn't seem to have them.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-06-2008, 09:21 AM   #7
Campfire Master
For stuff like that I use the 3M Command hooks. We hang a hot mitt and a pot holder on the wall next to the stove. If needed, they can be moved and leave no marks on the wall.
To hang a towel bar on a thin wall like ours, I use thin wall mollys. They hold tight and provide plenty of support for the bar.
AVid
AVid is offline   Reply With Quote
Old 06-10-2008, 10:05 AM   #8
Radio, you can purchase rolls of magnetized backing at craft or fabric stores, and glue your hook to it, then place on metal. Hope that helps.
granite is offline   Reply With Quote
Old 06-10-2008, 11:37 AM   #9
Cyber Phrenologist
Radio's Avatar
I found some magnetic hooks!
I wanted some plain ones like used to be popular, but I guess these fancy ones will do. Finally found them in the junk dept. at a Kroger grocery store.
Now what do you bet my range hood will be made of aluminium??
KU4OJ
Old 07-10-2008, 04:05 PM   #10
Newbie shopping for FR
Looking for studs
Just like at home it is best if you can find a stud to anchor things to. The walls are flimsy enough that if you just push on the wall you can get a good idea where the studs are. In our Flagstaff they used a little putty to hide the staples that they used to hold the wallboard to the studs. Once you have an idea where the studs are have a look for the little putty marks to be sure.
NorthernAvLover is offline   Reply With Quote
