Old 06-19-2016, 09:22 AM   #11
Blog: RVroadtripper.com
hbillsmith's Avatar
GC3 does remember settings. You do have the option of adjusting in pairs or individually. The user manuals are available on the LCI website. Also, check out their youtube videos.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 06-19-2016, 11:55 AM   #12
CaptnJohn's Avatar
Originally Posted by cbconway View Post
Does the Ground Control 3.0 system remember the hitch settings? Do the front legs operate independently or do you have to adjust them -- like when they came from the assembly line? I'm trying to understand how the electric system differs from the hydraulic. I already have the rear electric stabilizer jacks, so maybe the 4 point is better.
It will recall where you unhitched from. All 4 legs can be operated independently but have not yet found a reason to use that feature. Stabilizer jacks are meant to stabilize the camper after you have it level with 2x6s or blocks. The auto-level takes that out of the equation ~~ it levels and stabilizes with the push of 1 button.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 06-19-2016, 12:37 PM   #13
Retired
RubyDually's Avatar
Ground Control 3.0 owners manual
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 06-19-2016, 05:27 PM   #14
Retired
RubyDually's Avatar
When I repacked the bearings I used the rear jacks independently to take a lot of the weight off the axles and then used a floor jack with little effort to finish raising each wheel one at a time.
Old 06-21-2016, 05:02 AM   #15
I just had the LCI factory install my 6 point hydraulic system "after market" got last years rally price. Ended up being close to the same as the 6 point ground control system. Entire system was about $4,000 installed did not void any warranties. I do love only 4 hours from the factory though. I love the system and would not go without it again and I'm in my 30's. My camper is 42' and levels in about a minute.
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Dinostop is offline   Reply With Quote
Old 06-21-2016, 06:31 AM   #16
TURBS's Avatar
I dont think you can add a 6 point to a flagstaff 5th wheel "frame" isnt heavy enough.
A member here had it installed on his flagstaff and they had to add sooo much bracing that they said they'd not do it again.
Be warned.
Sent from my SCH-R530U using Tapatalk
Old 06-21-2016, 07:01 AM   #17
At lease for the Ground Control 3.0 system the manual talks about length being a consideration as well as weight. My Heritage Glen is under weight for a 6 point system but over length for a 4 point system. Best way to determine that is call Lippert. Also I have attached a link their manual that talks about how to determine if a 6 point or 4 point system is right for you. Again after talking to Lippert I ultimately decided on the 6 point hydraulic system myself.
http://www.lci1.com/assets/content/s...ual_EDITED.pdf
Eastlake, Ohio
Old 06-21-2016, 09:23 AM   #18
A member here had it installed on his flagstaff and they had to add sooo much bracing that they said they'd not do it again...
Yes, I was afraid that might be the case. I just hope a 4 point system is available. Thanks!
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
cbconway is offline   Reply With Quote
leveling
